I just received my Reef Angel yesterday, and this is probably a dumb question, but here goes:
I was able to get everything installed and running, connected up the wifi attachment, and can see everything in the reef angel client. I left my lights as relay 2 (default) and it shows as "Off" in the client, but it's providing power to that outlet. (Just in case I plugged them in wrong, I masked them all to "Off" in the client, but I was still receiving power at the outlet that I believe is relay 2.
I can make relay 8 (my moonlights) work correctly, masking it on and off in the client causes it to turn on and off.
What did I do wrong?
My internal memory:
// Autogenerated file by RAGen (v1.2.1.158), (03/20/2012 05:55)
// Memory_032012_0555.ino
// This file sets the default values to the Internal Memory
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOnMinute_write(0);
InternalMemory.MHOffHour_write(15);
InternalMemory.MHOffMinute_write(0);
InternalMemory.MHDelay_write(5);
InternalMemory.StdLightsOnHour_write(12);
InternalMemory.StdLightsOffHour_write(18);
InternalMemory.StdLightsOffMinute_write(0);
InternalMemory.DP1Timer_write(10);
InternalMemory.DP1RepeatInterval_write(60);
InternalMemory.DP2RepeatInterval_write(60);
InternalMemory.ATOTimeout_write(60);
InternalMemory.ATOHighTimeout_write(60);
InternalMemory.LEDPWMActinic_write(50);
InternalMemory.LEDPWMDaylight_write(50);
InternalMemory.WM1Timer_write(200);
InternalMemory.WM2Timer_write(354);
InternalMemory.HeaterTempOn_write(780);
InternalMemory.HeaterTempOff_write(785);
InternalMemory.ChillerTempOn_write(790);
InternalMemory.ChillerTempOff_write(785);
InternalMemory.PHMax_write(840);
InternalMemory.PHMin_write(550);
InternalMemory.SalMax_write(2550);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(140);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(128);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(128);
InternalMemory.PWMSlopeDurationA_write(60);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
}Code: Select all
// RA_032012_0555.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardFan(Port4);
