IO expansion module
Posted: Fri Mar 23, 2012 11:57 am
by ahmedess
whats it used for?
Re: IO expansion module
Posted: Fri Mar 23, 2012 12:03 pm
Buttons, Float switches, Relay contacts, flow meters
Posted: Fri Mar 23, 2012 12:09 pm
by ahmedess
so the channels can be used as input or output? What is the voltage on the output? Are they all digital channels or can they be set as A/D or D/A channels whether input or output channels?
Posted: Fri Mar 23, 2012 12:14 pm
They can be setup and input or output at 5VDC.
They are all digital. No A/D or D/A available.
Posted: Fri Apr 20, 2012 8:39 pm
by btorrenga
I'm confused, where is the IO module shown on the products web page? Is this the PWM module? I would like to configure several float switches to monitor various topoff tanks beyond the two included ATO ports included.
Posted: Fri Apr 20, 2012 9:43 pm
It's an special order item.
You can check the manual for it at
http://www.reefangel.com/Download.ashx
It looks just like the PWM expansion module.
Posted: Fri Apr 20, 2012 10:05 pm
by btorrenga
Ah, I see, thank you for the explanation. I would like to specially order an IO module and a Reef Angel Plus.
Posted: Tue May 01, 2012 7:01 pm
by tkeracer619
I have two of them. Great add on
I use them to monitor flow on my... Carbon, GFO, Bio Pellets, and return pump.
Posted: Sat May 05, 2012 12:37 pm
by abhi_123
tkeracer619 wrote:I have two of them. Great add on
How you are managing the flow? Simply with the module or some other device too?
