Issues setting up the WiFi Module with provided setup code
Posted: Sun Jun 05, 2011 8:40 am
Hi,
I've been trying to use the Wifi COnfig pde provided on reefangel.com but it can't compile which seems odd to me as I was able to send the "demo code" easily to my RA. I get tons of errors, saying it can't find files (cpp and h) altough they are in the proper location.
I've only uploaded the demo code so far but it worked.
Any ideas ?
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:22:31: error: ReefAngel_Globals.h: No such file or directory
In file included from C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:25:
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:29:66: error: ReefAngel_EEPROM.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:31:32: error: ReefAngel_NokiaLCD.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:32:27: error: ReefAngel_ATO.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:33:32: error: ReefAngel_Joystick.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:34:27: error: ReefAngel_LED.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:35:34: error: ReefAngel_TempSensor.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:36:29: error: ReefAngel_Relay.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:37:27: error: ReefAngel_PWM.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:38:29: error: ReefAngel_Timer.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:39:30: error: ReefAngel_Memory.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:26:28: error: ReefAngel_Wifi.h: No such file or directory
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:52: error: 'ParamsStruct' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:54: error: 'ReefAngel_NokiaLCD' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:55: error: 'ReefAngel_JoystickClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:56: error: 'ReefAngel_LEDClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:58: error: 'ReefAngel_ATOHighClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:59: error: 'ReefAngel_ATOLowClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:60: error: 'ReefAngel_TempSensorClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:61: error: 'ReefAngel_RelayClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:74: error: 'ReefAngel_TimerClass' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:75: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:78: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:79: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:80: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:88: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:102: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:103: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:104: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:105: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:106: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:107: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:108: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:109: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:110: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:111: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:114: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:115: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:116: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:117: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:118: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:119: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:120: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:121: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:122: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:123: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:124: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:125: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:126: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:130: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:162: error: 'byte' has not been declared
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:177: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:180: error: 'Total_Menus' was not declared in this scope
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:181: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:182: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\/ReefAngel.h:183: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:28: error: 'byte' does not name a type
C:\Users\astralmind\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:30: error: expected constructor, destructor, or type conversion before '(' token
Any ideas ?
