PaulTurner911 Code
PostPosted: Thu Oct 13, 2022 7:00 pm
Does anyone have a display menu that is capable of togging the main relay board ports?
New streamlined code
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    InternalMemory.OverheatTemp_write( 896 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.DelayedOn( Port2,90 );
    ReefAngel.Relay.DelayedOn( Port5,5 );
    //Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.Portal( "Paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
PostPosted: Wed Oct 19, 2022 5:00 am
Paulturner911 wrote:Does anyone have a display menu that is capable of togging the main relay board ports?
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Do you mean naming the ports? My code does that:
viewtopic.php?f=11&t=4662
Jack
PostPosted: Thu Oct 20, 2022 3:26 pm
I want to be able to turn them on and off from the actual controller joystick.
I also want a fail safe that if the PORT 1 is OFF, it turns off PORT 2 and PORT 5.
Long story short, my app doesn't work reliably, and I don't want to have to sign in to the portal to turn something off or on. I can see the controller anytime on the portal, but the app is random and will not connect if I want it to, but hours later it will toggle the ports I've fiddled with in the app. Then you come home to a pump turned off and a overflowed skimmer and a filter roller that wasted 20' of roll. SUCKS
Any help would be great. Thank you
PostPosted: Mon Oct 31, 2022 12:06 pm
I created this with the cloud wizard.
I'm having an issue where my skimmer is overflowing because the return pump is off. I made a if/then to turn off the skimmer and filter roller off if the return pump is ever off. This doesn't seem to work.
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.Relay.DelayedOn( Port2,10 );
    ReefAngel.Relay.DelayedOn( Port5,10 );
    ReefAngel.PWM.SetChannel( 4,MoonPhase() );
    if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port2 );
    if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port5 );
    if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.DelayedOn( Port2,10 );
    if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.DelayedOn( Port5,10 );
    ReefAngel.CloudPortal();
// RA_STRING1=U2FsdGVkX1+wzokeKHQCk87w7JvvcOREK6+LjmUjNMc=
// RA_STRING2=U2FsdGVkX19g+eSJzWd3/2eYdbXZT5v3evtlYFIGeqE=
// RA_STRING3=Nacho Network
// RA_LABEL LABEL_DAYLIGHT=Not Used
// RA_LABEL LABEL_ACTINIC=Not Used
Previous
Return to My PDE/INO file
