Setting a timer on a port that is already controlled
PostPosted: Sun Jun 07, 2020 8:28 am
To better balance my daily alkalinity, I'm interested in turning off my Carbondoser (fancy solenoid connected to CO2 tank for my Ca reactor) for a few hours in the middle of the night. The problem is, this relay/port is already set for CO2 control, tied to the pH read by my PH Expansion module
ReefAngel.CO2Control( Box1_Port1, InternalMemory.CO2ControlOff_read(), InternalMemory.CO2ControlOn_read(), true );
I can set simple time if/then statements, but I figure that if I set the port to time-off at say 1:00 am and then time-on at say 4:00 am, it would create a conflict in that my CO2 control code is telling the port one thing (to turn on/off based on Internal Memory settings), while the if/then statements would be telling it to turn on at 4 am and remain on until 1 am. The way out of this is to set two "off" values creating a range
if ( hour(now()) >= 1 ) ReefAngel.Relay.Off( Box1_Port1 );
    if ( hour(now()) <= 4 ) ReefAngel.Relay.Off( Box_Port1 );
Is this the best way to accomplish?
PostPosted: Sun Jun 07, 2020 8:41 am
Oops... I just realized that my if/then statement code won't work without "and". Can you include an "and" in the if/then statement code?
PostPosted: Sun Jun 07, 2020 6:40 pm
Yes you can use and and on your if statement.
Just make sure to add that line after your CO2Control function.
PostPosted: Sun Jun 07, 2020 9:09 pm
rimai wrote:Yes you can use and and on your if statement.
Great. What is the syntax for using “and” when linking two if/then statements?
PostPosted: Mon Jun 08, 2020 7:17 am
if ( hour(now()) >= 1 && hour(now()) <= 4 ) ReefAngel.Relay.Off( Box1_Port1 );
PostPosted: Mon Jun 08, 2020 11:09 am
Thanks! So the syntax for the logical function "and" is: <space>&&<space>, correct? Also, my pH Expansion has dropped out a couple of times, showing a pH of 0.00. Since 0.00 is lower than my Internal Memory "turn off" value, my Carbondoser shut-off until the value came back (wasn't out for long either time). I have my Carbondoser/regulator set such that my Carbondoser runs continuously, and my internal memory values are just there as a failsafe. My question is, if I add the if/then statement:
if ( ReefAngel.Params.PHExp <= 100 ) ReefAngel.Relay.On( Box1_Port1 ); //Keeps Carbondoser running in the event pH Expansion value is lost
would that nullify the problem in that my Carbondoser would remain 'on' in the event Expansion pH dropped to 0.00 (<=1.00)?
PostPosted: Tue Jun 09, 2020 5:59 am
Yes
Return to How do I code ...
