I hope I'm not shooting myself in the foot and defeating the purpose of monitoring salinity. I've been doing this manually and am confident in my ability to keep the tank stable in normal circumstances so I'm comfortable trying this out. We'll see.
Auto Calibrate Salinity Probe?
howaboutme
Re: Auto Calibrate Salinity Probe?
Thanks Curt! I think I understand. I'll play with this the next few days and report back.
Jack
howaboutme
Curt,
Can you check my code? I've adjusted the start time and run time. It compiles with no errors. I just want a 2nd eye before I load and test. Thanks!
// Set to start at 9:45am and run for 10 minutes
#define AUTO_SAL_START_HOUR 9
#define AUTO_SAL_START_MINUTE 45
#define AUTO_SAL_RUN_TIME 10
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port8Bit;
// Salinity Temp Compensation
ReefAngel.Salinity.SetCompensation(0);
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.CustomLabels[0]="ATO Pump";
ReefAngel.CustomLabels[2]="Light";
ReefAngel.CustomLabels[3]="Nero3";
ReefAngel.CustomLabels[4]="Return Pump";
ReefAngel.CustomLabels[5]="Unused";
ReefAngel.CustomLabels[6]="Unused";
ReefAngel.CustomLabels[7]="Heater";
ReefAngel.SingleATOLow( Port1 );
ReefAngel.StandardLights( Port2 ); // putting skimmer on timer
ReefAngel.StandardHeater( Port8 );
// First 10 minutes after WC disable ATO for port 1
static time_t wcTimer;
if (now()-wcTimer > 0 && now()-wcTimer < 600) {
ReefAngel.Relay.Off(Port1);
else {ReefAngel.SingleATOLow (Port1 );
// Compute the current time
int CurrentTime = NumMins(hour(), minute());
// Compute the starting time for the auto salinity calibration
int AutoSalStartTime = NumMins(AUTO_SAL_START_HOUR, AUTO_SAL_START_MINUTE);
// Compute the ending time for the auto salinity calibration by adding in the run time
int AutoSalEndTime = AutoSalStartTime + AUTO_SAL_RUN_TIME;
// Check if it's time to start the auto salinity calibration
if ( AutoSalStartTime == CurrentTime ) {
// Switch to Salinity Calibration ONLY if we are on the main / default menu
// Don't switch to the calibration menu if we are doing something else (water change, feeding, etc)
if ( (ReefAngel.DisplayedMenu == DEFAULT_MENU) || (ReefAngel.DisplayedMenu == MAIN_MENU) ) {
ReefAngel.ChangeMode = SAL_CALIBRATE_MENU;
// Check if we are at the end of the Run Time for the auto salinity calibration
if ( AutoSalEndTime == CurrentTime ) {
// Simulate a button press ONLY if we are still on the Salinity Calibration menu screen
if (ReefAngel.DisplayedMenu == SAL_CALIBRATE_MENU) {
ButtonPress++;
ReefAngel.Portal( "howaboutme" );
Jack
- Contact:
looks ok. your changing of the time looks good and it appears that you just copied my code (which is expected).
howaboutme
Thanks yes. I was more making sure I put your codes in the right place. Will report back.
Jack
howaboutme
this morning was the first scheduled auto calibration. looks like everything went smoothly. thank you!
Jack
- Contact:
awesome!howaboutme wrote:this morning was the first scheduled auto calibration. looks like everything went smoothly. thank you!
glad to hear that everything appears to be going good.
