Restore RA+
PostPosted: Mon Aug 12, 2019 6:40 am
by Paul_Velasco
So my RA+ took a dump, got a new board.
Is there anything I need to know before I reload everything from a backup?
Also, if I decide a new cloud controller is in the works do I have to recode everything when switching from an RA+?
Re: Restore RA+
PostPosted: Mon Aug 12, 2019 7:04 pm
by binder
Paul_Velasco wrote:So my RA+ took a dump, got a new board.
if you jump up to the RA Star, there's a few things that you have to change to make it work. it's not bad though, pretty straight forward.
Re: Restore RA+
PostPosted: Tue Aug 13, 2019 7:46 am
by Paul_Velasco
Well that did not work? Board is not lighting up. Think something shorted out. Is there are replaceable fuse somewhere on the board? Or Relay Modules?
When I plug in the Relay module to the controller I get a clicking but no power to the RA+
Re: Restore RA+
PostPosted: Tue Aug 13, 2019 8:59 am
There is no fuse.
Re: Restore RA+
PostPosted: Tue Aug 13, 2019 12:13 pm
by Paul_Velasco
Any suggestions on a fix? Or did I blow another board up?
Re: Restore RA+
PostPosted: Tue Aug 13, 2019 7:30 pm
It could be the relay box.
Do you have a universal relay box or a relay expansion module+relay box as Box1?
Re: Restore RA+
PostPosted: Thu Aug 15, 2019 10:23 am
by Paul_Velasco
Have this:
So two boxes
Re: Restore RA+
PostPosted: Thu Aug 15, 2019 10:25 am
Ok, so swap relay boxes and see if the head unit turns on.
