Com 3 only option and i get Can not program Board in Wizard
Re: Com 3 only option and i get Can not program Board in Wiz
Looking again at the contents of the folder, i see no where on the machine where avrdude.conf is present. Almost like it doesnt get downloaded when i Install the plugin?
Yes, it did help.
Thanks for helping troubleshoot this.
I found the problem. Please reload the webwizard page and let me know if it works now.
And we have success! Out of curiosity, is it something that i could of fixed if i have to ever re install or wipe the PC etc?rimai wrote:Yes, it did help.
I found the problem. Please reload the we bwizard page and let me know if it works now.
See below:
Compiling code for RA_STAR board
Number of Relay Expansion Modules: 1
Reef Angel Star
Progress: 100.00%
Your code was compiled sucessfully.
Attempting to upload your code to RA_STAR on local port COM9 ...
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
System wide configuration file is "C:/Users/derek/.arduino-create/avrdude/6.0.1-arduino5/etc/avrdude.conf"
Using Port : COM9
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 43.5 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e9801
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as FF
avrdude: reading input file "C:/Users/derek/AppData/Local/Temp/arduino-create-agent239405237/firmware.hex"
avrdude: writing flash (126666 bytes):
Writing | ################################################## | 100% 31.64s
avrdude: 126666 bytes of flash written
avrdude: verifying flash memory against C:/Users/derek/AppData/Local/Temp/arduino-create-agent239405237/firmware.hex:
avrdude: load data flash data from input file C:/Users/derek/AppData/Local/Temp/arduino-create-agent239405237/firmware.hex:
avrdude: input file C:/Users/derek/AppData/Local/Temp/arduino-create-agent239405237/firmware.hex contains 126666 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 27.21s
avrdude: verifying ...
avrdude: 126666 bytes of flash verified
avrdude: safemode: Fuses OK (H:FF, E:D8, L:FF)
avrdude done. Thank you.
Your code was uploaded sucessfully.
Awesome.
No, it was something on the backend here.
Great!rimai wrote:Awesome.
Thanks!! Now i can actually get of my lazy rump and get this tank wet, and start the next level of programming. Need to set one of the floats to shut off my skimmer if tripped etc. I just wanted to get the base code done for ATO so i can get the tank cycling, and get my tablet configured for web access etc.
Thanks again! I was starting to think i went crazy, and was searching for registry keys based off application logs thinking it was some security blocking it.
Hopefully nthe last question for a while. I brought it back to the tank and plugged it into power so I could test my tablet and make sure it gets on the network. All I get is a green power light but touch screen doesn't react to my touchrimai wrote:Awesome.
NVM it booted. Figured first boot would take a while. Now to get.my tablet working.rimai wrote:Awesome.
