Water change mode and Vortech
Appleseed
Post by Appleseed »
Hi
I am trying to set my mp40s to a constant speed when activating water change mode, it kind of works but it seems like the pumps are trying to run at constant and another mode, ie they run at constant for a moment the a lower speed then ramp up for a second or two the change to some other speed.
Any ideas would be appreciated.
My code:
byte vtechmode;
byte vtechspeed;
byte vtechpercent;
boolean bFeeding=false;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//Custom Main, Graph & Menu
  //      ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(3,255,6,2," Reef of Low");
  ReefAngel.LCD.DrawDate(7, 120);
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
   ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  vtechmode=ReefAngel.RF.Mode;
  vtechspeed=ReefAngel.RF.Speed;
  vtechpercent=ReefAngel.RF.Duration;
  ReefAngel.LCD.Clear(255, 35, 20, 20, 85);
  ReefAngel.LCD.DrawText(0,255,18,21,"EcoSmart Mode");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,25,31,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,31,"Lagoonal");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,31,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,25,31,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,31,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,31,"STM_NTM.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,31,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,31,"Night");
  ReefAngel.LCD.DrawText(2,255,32,42,"Speed");
  ConvertNumToString(text, vtechspeed, 1);
  if (vtechspeed )ReefAngel.LCD.DrawLargeText(0,255,35,51,text);
  ReefAngel.LCD.DrawText(23,255,32,62,"Duration");
  ConvertNumToString(text, vtechpercent, 1);
  if (vtechpercent) ReefAngel.LCD.DrawLargeText(0,255,35,70,text);
  ReefAngel.LCD.DrawText(0,255,10,80,"T1");
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 88, text, Num8x8);
 ReefAngel.LCD.DrawText(0,255,50,80,"T2");
  ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 50, 88, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,80,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 85, 88, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
  ReefAngel.FeedingModePorts = Port4Bit; //| Port6Bit | Port7Bit;
  // ReefAngel.WaterChangePorts = Port4Bit | Port7Bit;
  InternalMemory.OverheatTemp_write( 290 );
  ReefAngel.Relay.On( Port7 );
  //    ReefAngel.Relay.On( Port8 );
  ReefAngel.DCPump.FeedingSpeed=100;
  ReefAngel.Timer[FEEDING_TIMER].SetInterval(2100);
  //   if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port7); // Turn Skimmer off if Return is off and water level increases in sump
    //    ReefAngel.Relay.Set(Port7,ReefAngel.LowATO.IsActive()); // Turn Skimmer on if Return is on and water level in the sump is norma
//  ReefAngel.StandardHeater( Port1,251,261 );
//  ReefAngel.StandardHeater( Port2,251,261 );
  //    ReefAngel.StandardFan( Port3,271,281 );
  //    ReefAngel.StandardLights( Port3,20,0,5,0 );
  //    ReefAngel.StandardLights( Port6,20,0,0,0 );
  ReefAngel.StandardLights( Port4,8,0,20,0 );   //SKIMMER
  ReefAngel.StandardLights( Port5,20,0,8,0 );   //REFUG
  //    ReefAngel.DosingPumpRepeat( Port8,0,180,30);
//  ReefAngel.CO2Control ( Port8,650,670 ); //was 630 - 640
  ReefAngel.DosingPumpRepeat( Port3,0,180,180);
  //    ReefAngel.RF.SetMode(Constant,80,5);
  //    ReefAngel.RF.SetMode(Random2,50,5);
  //    ReefAngel.RF.SetMode(Smart_NTM,50,10);
  //    ReefAngel.RF.SetMode(Smart_NTM,60,8);
  //    ReefAngel.RF.SetMode(Custom,30,0); //Custom Mode Sync
  //    ReefAngel.RF.SetMode(Custom,50,1); //Custom Mode Anti-Sync
  //    ReefAngel.RF.SetMode(Custom,50,2); //Custome Mode Back of tank
///////    ATTEMPT TO CHANGE MODE @ TIMES
  if ( ReefAngel.RF.Mode != Feeding_Start)
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.RF.SetMode(Constant,80,5);
    if (hour()==10)
      ReefAngel.RF.SetMode(ReefCrest,30,2);
    else if (hour()>=0 && hour()<1)
      ReefAngel.RF.SetMode(ReefCrest,30,1);
    else if (hour()>=1 && hour()<2)
      ReefAngel.RF.SetMode(ReefCrest,40,3);
    else if (hour()>=2 && hour()<3)
      ReefAngel.RF.SetMode(ReefCrest,60,2);
    else if (hour()>=3 && hour()<4)
    else if (hour()>=4 && hour()<5)
    else if (hour()>=5 && hour()<6)
      ReefAngel.RF.SetMode(ReefCrest,20,1);
    else if (hour()>=6 && hour()<7)
      ReefAngel.RF.SetMode(LongPulse,60,10);
    else if (hour()>=7 && hour()<8)
      ReefAngel.RF.SetMode(Lagoon,40,3);
    else if (hour()>=8 && hour()<9)
      ReefAngel.RF.SetMode(Lagoon,50,4);
     else if (hour()>=9 && hour()<10)
      ReefAngel.RF.SetMode(Lagoon,60,7);
    else if (hour()>=10 && hour()<11)
      ReefAngel.RF.SetMode(Lagoon,50,6);
    else if (hour()>=11 && hour()<12)
      ReefAngel.RF.SetMode(Lagoon,40,2);
   else if (hour()>=12 && hour()<13)
      ReefAngel.RF.SetMode(Constant,60,4);
    else if (hour()>=13 && hour()<14)
      ReefAngel.RF.SetMode(Lagoon,20,3);
   else if (hour()>=14 && hour()<15)
     ReefAngel.RF.SetMode(Lagoon,60,4);
    else if (hour()>=15 && hour()<16)
      ReefAngel.RF.SetMode(LongPulse,50,15);
    else if (hour()>=16 && hour()<17)
      ReefAngel.RF.SetMode(Lagoon,50,5);
    else if (hour()>=17 && hour()<18)
      ReefAngel.RF.SetMode(Lagoon,40,6);
    else if (hour()>=18 && hour()<19)
      ReefAngel.RF.SetMode(Smart_NTM,40,20);
    else if (hour()>=19 && hour()<20)
      ReefAngel.RF.SetMode(Smart_NTM,60,15);
    else if (hour()>=20 && hour()<21)
      ReefAngel.RF.SetMode(Constant,70,4);
    else if (hour()>=21 && hour()<22)
      ReefAngel.RF.SetMode(Lagoon,60,5);
    else if (hour()>=22 && hour()<23)
      ReefAngel.RF.SetMode(Lagoon,40,10);
    else if (hour()>=23 && hour()<0)
      ReefAngel.RF.SetMode(Lagoon,10,5);
      ReefAngel.RF.SetMode(ReefCrest,40,20);
  //    ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  //    ReefAngel.PWM.SetDaylight( NutrientTransportMode(80,100,10,true) );
//  if (hour()>=8 && hour()<10)
//    ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on sync mode
//    else if (hour()>=10 && hour()<16)
//    ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
//    else if (hour()>=16 && hour()<17)
//    ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
//    else if (hour()>=17 && hour()<20)
//    ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,4,true) );
//    else if (hour()>=20 && hour()<24)
//    ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
//    else
Re: Water change mode and Vortech
Try moving this:
    if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) ReefAngel.RF.SetMode(Constant, 80, 5);
To the end of the code as the last check.
Appleseed
Post by Appleseed »
Hi Roberto,
I tried what you suggested and it still does it, it definatley sounds like the MP's are trying to run both the waterchange (Constant) and the tech mode thats set based on the time the water change mode is activated.
///////    CHANGE Vortech MODE @ TIMES
//    if ( ReefAngel.RF.Mode != Feeding_Start)
    if (hour()==10)
      ReefAngel.RF.SetMode(Lagoon,50,3);
