Putting Skimmer on Timer
howaboutme
Post by howaboutme »
I want to put my skimmer on a timer so I've called Port 2 as standard lights but it didn't work.
I had the same code (or similar) previous, and it worked fine. Can someone check the code and let me know where I've missed something? Thanks!
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
    // Salinity Temp Compensation
    ReefAngel.Salinity.SetCompensation(0);
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
        ReefAngel.CustomLabels[0]="ATO Pump";
        ReefAngel.CustomLabels[1]="Skimmer";
        ReefAngel.CustomLabels[2]="MP10 Left";
        ReefAngel.CustomLabels[3]="MP 10 Right";
        ReefAngel.CustomLabels[4]="Return Pump";
        ReefAngel.CustomLabels[5]="Doser Alk";
        ReefAngel.CustomLabels[6]="Unused";
        ReefAngel.CustomLabels[7]="Inkbird";
    ReefAngel.StandardLights( Port2 ); // putting skimmer on timer
    ReefAngel.Relay.DelayedOn(Port2 );
    ReefAngel.Relay.DelayedOn(Port3 );
    ReefAngel.Relay.DelayedOn(Port4 );
    ReefAngel.DosingPumpRepeat1( Port6 )
     //DoserAlk Schedule
              ;if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
              ReefAngel.Relay.Off(Port6);
     // First 10 minutes after WC disable ATO for port 1
          static time_t wcTimer;
          if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
          if (now()-wcTimer > 0 && now()-wcTimer < 600) {
          ReefAngel.Relay.Off(Port1);
          else {ReefAngel.SingleATOLow (Port1 );
    ReefAngel.Portal( "howaboutme" );
Jack
Re: Putting Skimmer on Timer
You have port2 on two fundtions.
Delete or comment the second line
howaboutme
Thanks Roberto! I realized that was the issue as well. Appreciate the reply.
Jack
