Putting Skimmer on Timer
Posted: Fri Oct 28, 2022 7:25 am
I want to put my skimmer on a timer so I've called Port 2 as standard lights but it didn't work.
I had the same code (or similar) previous, and it worked fine. Can someone check the code and let me know where I've missed something? Thanks!
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
// Salinity Temp Compensation
ReefAngel.Salinity.SetCompensation(0);
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomLabels[0]="ATO Pump";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="MP10 Left";
ReefAngel.CustomLabels[3]="MP 10 Right";
ReefAngel.CustomLabels[4]="Return Pump";
ReefAngel.CustomLabels[5]="Doser Alk";
ReefAngel.CustomLabels[6]="Unused";
ReefAngel.CustomLabels[7]="Inkbird";
ReefAngel.StandardLights( Port2 ); // putting skimmer on timer
ReefAngel.Relay.DelayedOn(Port2 );
ReefAngel.Relay.DelayedOn(Port3 );
ReefAngel.Relay.DelayedOn(Port4 );
ReefAngel.DosingPumpRepeat1( Port6 )
//DoserAlk Schedule
;if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
ReefAngel.Relay.Off(Port6);
// First 10 minutes after WC disable ATO for port 1
static time_t wcTimer;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
if (now()-wcTimer > 0 && now()-wcTimer < 600) {
ReefAngel.Relay.Off(Port1);
else {ReefAngel.SingleATOLow (Port1 );
ReefAngel.Portal( "howaboutme" );
