Portal Issues
madmarks
Portal Issues
Post by madmarks »
I have a Reef Angel + w/ the standard wifi module.
When I look at the settings I see:
Version 1.1.3
WiFi WDT
1
I can reach the controller over my local network using http://<ip of RA>:2000/wifi and see the correct settings and probe readings.
When using the browser on my phone to http://<public IP>:2000/wifi I get the UAPP screen but all settings are 0; the screen format, tabs and reef angel logo are all as they should be.
When I go to the Portal I do not see my data. I get:
Screen Shot 2021-06-15 at 10.26.17 PM.png (32.31 KiB) Viewed 14865 times
Using the setup wizard's section for WiFi, I am prompted for what basically becomes the DDNS name. There is not any place to put a key or my public IP for my system in the Wizard. Note:I have entered the public IP in the settings option in the UAPP.
What am I missing? Do I update a profile on the Portal ? Do I need the cloud WiFi expansion?
Thanks;
John Marks
Re: Portal Issues
You need to update the firmware of your module:
https://forum.reefangel.com/viewtopic.php?f=3&t=4601
Then, you need to setup port forwarding on your router to be able to allow external access.
madmarks
Re: Portal Issues
Post by madmarks »
Thank you.
It took a few tries. The SSID kept getting corrupted and it would not connect. I put an extra line in and that took care of the problem. It is all up a running on the portal now.
Again thank you
JohnGreenCloG
Re: Portal Issues
Post by JohnGreenCloG »
Hello, I'm new here. And I like the fact that a lot of useful information can be found here
