Is RA right for me?
PostPosted: Sat Apr 09, 2016 3:07 pm
by orucco
Hello and thanks for the most informative forum! I am on a limited income and am retired after 40 years in the telephone industry. I am comfortable with Windows based PCs but do not know C+ or programming. I have a 75 gal reef with soft corals and a sump. My lights are Aquatclife 6 bulb t5 with 2 channels on a single AC cord. I also have a Red Sea wave controller that my 3 Korallia Evolution power heads and my Eheim 1262 return pump connect to and it has a feed mode which turns off all pumps except 1 pH for 30 minutes. dose daily by hand 2 part and topoff manually. I would like a controller for heater protection auto topoff, and 2 part dosing at least right now. I do like the unlimited possibilities RA seems to offer and do enjoy some diy. Apex seems to have many firmware updates and problems and Reefkeeper seems o lack product support by the manufacturer from viewing there forums. RA seems to have very helpful and informative support by maker and members! Sorry for the long post but just want the best I can afford and a pleasant experience. Thanks for any information you can give!.............Tony.
Re: Is RA right for me?
PostPosted: Sat Apr 09, 2016 3:36 pm
Welcome aboard. Sounds like you're in the right place. Don't be scared of the programming. If you can think logically and work through it, we can help and the wizard gets you pretty close.
PostPosted: Sat Apr 09, 2016 3:37 pm
You can download the installer and play with the wizard and start looking at code before you even order.
PostPosted: Sat Apr 09, 2016 6:28 pm
by orucco
Thank you! I did download it and will get familiar with it. I am still not clear on the analog or pwn? If I get the analog does it cover both in case I need it in the future? Thanks again!
PostPosted: Sat Apr 09, 2016 9:03 pm
Yes you can change it later either way. Unless you switch to LED or Jaebo style powerheads you won't need them.
PostPosted: Wed Jul 13, 2016 11:40 am
by rickztahone
lnevo wrote:You can download the installer and play with the wizard and start looking at code before you even order.
Where might one download this?
PostPosted: Thu Jul 14, 2016 3:55 pm
by cosmith71
"Download", near the top right of every page on this site. :mrgreen:
