Best way to build my coding?
Re: Best way to build my coding?
DO I need to wipe my memory file and reload it with less 'stuff' in it, the things i dont need (MH lighting, dosing, etc), in order to lower my sketch size?
No, the memory file just sets the values to the Internal Memory for use with the sketch / program files later on.
The more things you enable in the Features file (Features Tab in the program), the larger the sketch size will be.
Date & Time Setup requires a lot of space, so it's advised to not include it.
Simple Menu reduces a lot of space, so it's advised to use it.
If you are using the Client Suite or any of the monitoring applications (Android, iPhone/iPad apps or Status App), you must have wifi enabled for communications with the controller. Wifi does require a lot of space.
Bottom line, the more stuff you have the controller do, the larger the sketch size will be.
Make sure the paths are set correctly too, like the earlier post:
http://forum.reefangel.com/viewtopic.php?p=5291#p5291
SO WIERD! I don't understand why now when I complie it 24274 bytes but last night compling the same code is was 31k
Its ALIVE! Thanks everyone for you help. I did run RAGen static and the seemed to fix all my issues. The other download seemed to wrok for a few start ups than never again lol. /shrug
