Anyone programming from a Mac?
Re: Anyone programming from a Mac?
any changes to the libraries needs to be done with arduino closed. if not closed, just restart arduino.
once restarted, make sure that you have the proper board selected (reefangel board that is).
run the cb tool parser again (just to make sure).
then try to compile the code.
arduino is a little finicky with its libraries and all.
Yeah, I quit Arduino, replaced all the libraries with the dev ones, then relaunched Arduino. I quit and relaunched again just grins, and I ensured that the Reef Angel Star was selected.binder wrote:any changes to the libraries needs to be done with arduino closed. if not closed, just restart arduino.
Running your tool is successful. It's only when I verify the code is when I get these class errors. Again, the code I have is a straight copy/paste from the web wizard.
- Screen Shot 2020-10-25 at 4.10.12 PM.png (148.5 KiB) Viewed 4696 times
Does this code snippet look right?
- Screen Shot 2020-10-25 at 4.33.15 PM.png (184.14 KiB) Viewed 4694 times
Remove that blank wiring.h file you created. it's not needed at all and is probably causing problems.
the libraries need to be in Documents/Arduino/libraries
(full path is actually /User/username/Documents/Arduino/libraries)
i can't remember if it's /users or /user on macos.
I recall dealing with something like these issues with someone else just recently and don't recall what the solution was. I'm going to look more now.
that extra [1] is not needed because you don't have 2 relay boxes. remove those references.ReeferRyan wrote:Does this code snippet look right?
FeedingModePortsE[1] (or whatever it is exactly)
you are referencing an element of an array that doesn't exist. Those port arrays are only the size of expansion boxes. I think the wizard messed up generating that code. you only have 1 relay box with the star, so remove all the lines that reference the 1st index (second item in array).
That wiring.h file was removed when I replaced the libraries with the ones from dev.binder wrote:Remove that blank wiring.h file you created. it's not needed at all and is probably causing problems.
And yes, the libraries are in /Users/username/Documents/Arduino/libraries
I did that, but it's still complaining about:binder wrote:that extra [1] is not needed because you don't have 2 relay boxes. remove those references.ReeferRyan wrote:Does this code snippet look right?
'class ReefAngelClass' has no member named 'FeedingModePortsE'; did you mean 'FeedingModePorts'?
'class ReefAngelClass' has no member named 'WaterChangePortsE'; did you mean 'WaterChangePorts'?
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port4Bit;
'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'; did you mean 'OverheatShutoffPorts'?
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port3Bit;
'class ReefAngelClass' has no member named 'LightsOnPortsE'; did you mean 'LightsOnPorts'?
'class ReefAngelClass' has no member named 'BuzzerOn'
if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
'class ReefAngelClass' has no member named 'BuzzerOff'
'class RA_Wifi' has no member named 'Cloud'
ReefAngel.Network.Cloud();
'class ReefAngelClass' has no member named 'ShowTouchInterface'; did you mean 'ShowInterface'?
ReefAngel.ShowTouchInterface();
I'm stumped and getting frustrated with it.
Sure...this is what the web wizard created for me.binder wrote:Can you post your current code?
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[1] = 0;
ReefAngel.LightsOnPortsE[1] = 0;
InternalMemory.OverheatTemp_write( 810 );
ReefAngel.StandardHeater( T1_PROBE,Box1_Port1,775,800 );
ReefAngel.StandardLights( Box1_Port3,20,30,7,0 );
ReefAngel.StandardATO( Box1_Port4,30 );
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.isBusLock() ) buzzer=true;
// RA_STRING1=U2FsdGVkX1+uXmgleL3ALdgM9jXq4EPIkMaDG99HFL8=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT15=Port 15
// RA_LABEL LABEL_PORT13=Port 13
// RA_LABEL LABEL_PORT18=Port 18
// RA_LABEL LABEL_PORT16=Port 16
// RA_LABEL LABEL_PORT11=Port 11
// RA_LABEL LABEL_PORT17=Port 17
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT14=Port 14
// RA_LABEL LABEL_PORT12=Port 12
And this is the code where I removed references to the second relay expansion module.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
Well, both of those options / codes you posted compile just fine for me. I get no errors when I "verify". Here's the code that I used (from what you posted).
So, that makes me think there is an issue with the libraries location on your computer. I'm running macos 10.15.7 and arduino 1.8.13 plus the latest dev libraries.
My libraries folder contains exactly the same folders as the dev release (plus some extra code that I created). So it has to be your configuration/setup. Make sure that your Arduino preferences shows the Sketchbook location as:
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
/Users/yourname/Documents/Arduino
Mine is: /Users/binder/ownCloud/Documents/Arduino
Ok, so I just quit Arduino and then emptied the libraries folder. Then I downloaded the entire dev library from GitHub. I moved all those libraries into the /Users/rsweeney/Documents/Arduino/libraries folder. I launched Arduino and verified that the Sketchbook location is set to /Users/rsweeney/Documents/Arduino. I pasted the code you said was successful, then ran the CBTool and it did its thing. Then I clicked the Verify button and got the same exact errors as before. What could I possibly be doing wrong?binder wrote:Well, both of those options / codes you posted compile just fine for me. I get no errors when I "verify". Here's the code that I used (from what you posted).
My libraries folder contains exactly the same folders as the dev release (plus some extra code that I created). So it has to be your configuration/setup. Make sure that your Arduino preferences shows the Sketchbook location as:Code: Select all
/Users/yourname/Documents/Arduino Mine is: /Users/binder/ownCloud/Documents/Arduino
Ok. Gonna do a couple more checks.
1. Paste the output of running my tool. It should be something like this:
2. If that looks good, then check out the version of the libraries.
Open up the libraries/ReefAngel/ReefAngel.h file and look for the line #define ReefAngel_Version "...". It will be towards the top, after the comments. Maybe around line 25. It should say this:
I'm having you check these because it sounds like the functions are not being enabled. The libraries contain a lot of define statements that remove sections of code that are not necessary or relevant. If the proper defines are not enabled, then the functions won't exist, which is what it sounds like is happening to you.
3. Lastly, check if you have an "update" folder inside your Sketch folder. You already created a "tools" folder in there. I'm guessing that you will need to create the "update" folder. If you do, then you will need to add the features.txt file I have attached to this post. THEN you can re-run my CB Tool to process the sketch and everything should work. If it does, great and my apologies for not having that available for you. I need to fix up the instructions and fix up the plugin to display proper error messages and warnings (that's what I get for just copying the code and not paying attention to it).
CBTool v2.0.1
Generating Features file from sketch_oct25a.ino
Watchdog Timer
Version Menu
Relay Expansion Module
Reef Angel Star
Number of Relay Expansion Modules: 1
Simple Menu
Finished detecting Features.
Generating Custom Labels file from sketch_oct25a.ino
Found Label: LABEL_PORT15 - Port 15
Found Label: LABEL_PORT13 - Port 13
Found Label: LABEL_PORT18 - Port 18
Found Label: LABEL_PORT16 - Port 16
Found Label: LABEL_PORT11 - Port 11
Found Label: LABEL_PORT17 - Port 17
Found Label: LABEL_PORT14 - Port 14
Found Label: LABEL_PORT12 - Port 12
Finished detecting Labels.
Ready to compile & upload.
#define ReefAngel_Version "1.1.3"
- feature.txt
- Features files
- (6.71 KiB) Downloaded 314 times
After creating the "update" folder and putting the feature.txt file in it, the output of your tool NOW includes:
CBTool v2.0.1
Generating Features file from Reef_Angel_Initial_Setup.ino
Watchdog Timer
Version Menu
Reef Angel Star
Simple Menu
Generating Custom Labels file from Reef_Angel_Initial_Setup.ino
Found Label: LABEL_PORT13 - Refugium Light
Found Label: LABEL_PORT11 - Heater
Found Label: LABEL_PORT14 - ATO
Found Label: LABEL_PORT12 - Return Pump
Those two bold lines were not there before.
And now the code compiles and I was able to upload it to the RA!!!
Curt, seriously, thank you for your assistance. I was just about ready to send this thing back.
CBTool v2.0.1
Watchdog Timer
Version Menu
Reef Angel Star
Simple Menu
I am also a lot to blame. I need to come up with a solid solution for Catalina release.
The background story is that when Catalina was released, Apple locked all 32-bit applications and the avrdude that is responsible for the upload of the code was compiled on 32-bit.
Since then, Arduino has patched the plugin to download the new 64-bit version of avrdude, but the current plugin needs to be updated and the webwizard also needs to be updated.
I had my MacOS VM crash and I just had it rebuilt from scratch, which should allow me to fix this thing now.
@ReeferRyan, would you be interested in working with me on fixing this since you are the first one with Catalina that can actually test things for me?
Awesome! Sorry it took so long to get it figured out. I just "assumed" those missing folders/files existed because they were already there from a previous install.ReeferRyan wrote:After creating the "update" folder and putting the feature.txt file in it, the output of your tool NOW includes:
CBTool v2.0.1
Watchdog Timer
Version Menu
Reef Angel Star
Simple Menu
Yeah, I can help you. Sorry I didn't see this until now. Let me know what you need from me.rimai wrote:I am also a lot to blame. I need to come up with a solid solution for Catalina release.
