Reefology's code
PostPosted: Thu Feb 16, 2017 4:16 am
    InternalMemory.LCDID_write(255); //this line was added when i got a replacement RA+ board
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.Relay.DelayedOn(Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
    ReefAngel.DCPump.AntiSyncOffset = 125;
    // Wavemaker
    if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
        ReefAngel.Relay.Off(Port6);
        ReefAngel.WavemakerRandom( Port6, 30, 300 ); // random between 30 and 300 seconds
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800)
    ReefAngel.DCPump.Mode=ReefCrest;
    ReefAngel.DCPump.Speed=75;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Gyre,40,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,70,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
    else if (hour()>=21 && hour()<22) // 9pm and 10pm
    ReefAngel.DCPump.SetMode( ShortPulse,85,30 );
    else if (InternalMemory.DCPumpMode_read()==11)
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
PostPosted: Wed Oct 11, 2017 2:36 pm
Hoping someone can help with this. I'd like to add Seasonal changes to my code but can't get it to compile.
void SeasonalTemps ()
  static int heatArray[][2] = { {782,786},// default in case of error in month=0 (June)
                    {760,764},//January (winter)
                    {764,768},//February (winter)
                    {765,769},//March (early spring)
                    {769,773},//April (spring)
                    {775,779},//May (spring)
                    {782,786},//June (early summer)
                    {789,793},//July (summer)
                    {796,800},//August (summer)
                    {786,790},//September (early fall)
                    {777,781},//October (fall)
                    {770,774},//November (fall)
                    {765,769} };//December (early winter)
  ReefAngel.StandardHeater( Port3,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
where exactly do I input this?
PostPosted: Thu Oct 12, 2017 7:15 pm
you have to simply copy the entire function and paste it into your INO file, most likely at the end of it. well after the last curly brace of the loop.
PostPosted: Fri Oct 08, 2021 5:15 am
  static int heatArray[][2] = { {780,784},// default in case of error in month=0 (May)
                    {764,768},//January (winter)
                    {768,772},//February (winter)
                    {772,776},//March (early spring)
                    {776,780},//April (spring)
                    {780,784},//May (spring)
                    {784,788},//June (early summer)
                    {788,792},//July (summer)
                    {784,788},//August (summer)
                    {780,784},//September (early fall)
                    {776,780},//October (fall)
                    {772,776},//November (fall)
                    {768,772} };//December (early winter)
  ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
    SeasonalTemps ();
    ReefAngel.ActinicLights( Port2 ); //ATS pump
    ReefAngel.DayLights( Port3 ); //ATS light
    ReefAngel.StandardLights( Port4, 23,0,7,0); //Skimmer 11pm-7am
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // SW 8
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    //ReefAngel.DCPump.AntiSyncOffset = 125; // % (0-255) of main pump (Sync)
    // koralia 1150
    // if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
    // else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
    // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
    changeMode=false;
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Mode=Else;
    ReefAngel.DCPump.Speed=80;
    // Night mode (go to 30%)
    } else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=40;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    } else {
Previous
Return to Ask anything here
Users browsing this forum: No registered users and 5 guests
