Page 1 of 2
wifi attachment help
PostPosted: Mon Oct 14, 2019 8:47 pm
by Reefology
Hi,
I recently changed my router and tried to change my ssid and passphrase on the RA+ wifi attachment with no luck. It worked flawlessly for years until I changed my router and now not sure how to proceed.
I followed the wifi setup documentation for all 3 methods and the result is always the same, IP address is 0.0.0.0;2000 and lights are flashing blue and green on the attachment.
can someone please help?
thanks
Re: wifi attachment help
PostPosted: Mon Oct 14, 2019 9:30 pm
Does the SSID or pwd have a space? If so, replace it with a $
PostPosted: Tue Oct 15, 2019 3:57 am
by Reefology
Hi Roberto, no neither ssid or passphrase have a space.
I reset WiFi attachment to factory settings and tried all 3 setup methods and still no luck. What else can I try?
PostPosted: Tue Oct 15, 2019 9:26 am
Do you get any response from the module when you use the Tera term method?
PostPosted: Tue Oct 15, 2019 5:20 pm
by Reefology
no I don't get anything?
PostPosted: Tue Oct 15, 2019 5:55 pm
Can you post the log that you get?
Are you sure you are selecting the correct COM port?
PostPosted: Tue Oct 15, 2019 6:18 pm
by Reefology
im definitely selecting the correct COM port.
not getting any log at all...I don't get the screen shown in step 16 of the wifi manual, screen is blank? not sure what to do?
PostPosted: Tue Oct 15, 2019 6:26 pm
by Reefology
still blinking blue and ip is 0.0.0.0;2000
here is the log I get with WiFi utility:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port /dev/tty.usbserial-A402NUWP
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to /dev/tty.usbserial-A402NUWP
< CMD
> reboot
< reboot
Wifi Attachment Connected to /dev/tty.usbserial-A402NUWP
* Please, enter a SSID
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 88548 3 wifly-GSX-441-r1057
< 26 88548 3 wifly-GSX-441-r1057
< 27 1052 10 user
< 122 Free, Boot=26, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Deri
< set w s Deri
< AOK
< <4.41>
> set w p erefre
< set w p erefre
< AOK
< <4.41>
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Deri
< Chan=1
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.41>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=255.255.255.0
< GW=0.0.0.0
< HOST=104.36.18.155:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router CGN3ACSMR
PostPosted: Wed Oct 16, 2019 10:30 am
Can you make sure the router can do B or G, because it cannot do N.
PostPosted: Wed Oct 16, 2019 2:53 pm
by Reefology
Sorry Roberto, I have no idea what that means or how to change it (if possible).
I received a new router from my service provider. Should I call them to have it switched?
