ATOLow Delay
PostPosted: Mon Jun 28, 2021 11:30 am
I am looking for a way to put a delay on the standard ATO low switch. My DC pump causes a little turbulence in that chamber.
If ATO is low for longer than x then turn on the standard ATO port.
PostPosted: Mon Jul 05, 2021 9:40 am
Anyone? Not possible?
PostPosted: Wed Jul 07, 2021 3:40 pm
clw143 wrote:Anyone? Not possible?
almost anything is possible.
are you just using the ato low switch? like once it gets triggered you want a delay of x seconds before the outlet turns on. then you want it to run until when? until it is not triggered?
PostPosted: Wed Jul 07, 2021 3:42 pm
you can also look at the libraries and specifically look at the metalhalide function(s). they implement a delay before turning on to limit the power draw at startup.
something like that can be implemented, only you will have to use the function call for the ato low switch.
PostPosted: Sat Jul 17, 2021 2:30 pm
I'm using the standard low and high. I just want the low active for x (maybe 5 seconds) before triggering the ato pump port and run until the high switch is active.
So just like normal but with some deadband on the low switch.
Return to Standard
