RA Star Instability
PostPosted: Wed Sep 08, 2021 2:01 pm
I recently upgraded from RA Plus to RA Star, and I am experiencing some odd behavior. Some of the symptoms include:
  • All I/O expansion channels briefly flash to "on" and then back to their normal values
  • Water levels briefly change to 0 and then back to their normal values
  • pH probes show very high or very low values and eventually return to normal
When I compiled in Arduino recently, I believe I saw the following message:
"Low memory available, stability problems may occur."
Could this be related to the issues I'm seeing? I didn't have these same issues with RA Plus.
I'm happy to do further debugging, if anyone has any ideas on what steps to take next.
PostPosted: Fri Sep 10, 2021 10:41 am
Anyone have anything thoughts on this? Right now, the controller is actually working against me. My skimmer is shutting down because it thinks the skimmate container is full. My pH values are killing my kalk reactor and calcium reactor. But these changes only last a second before returning to correct values.
PostPosted: Mon Sep 13, 2021 8:55 pm
Try moving the power cables away from the USB cables and sensor cables
Return to Standard
Users browsing this forum: No registered users and 10 guests
