ReefAngel Plus and other goodies for sale. - sold
PostPosted: Wed Nov 23, 2022 11:22 am
SOLD
I decided to move to another direction for my controller options and my trusted reefangel plus is for sale. Please check the notes for the conditions at the end.
ReefAngel Plus and Relay Box - $150
Wifi Attachment - $80
Bluetooth Attachment - $50
Expansion hub - $40
RF Module - $40
Multi-Water Level - $90
Everything Together $375 plus shipping
ReefAngel Plus - Everything seems to be working as you can see from the pictures. LCD is in great shape. I can not control the outlets. I lost my SVGA cable and I think the cable I found does not have all pins connected. Just the relay box and LCD worth the price.
Wifi Attachment and Bluetooth attachment work great a a pair
Multi-Water Level expansion - this was the main reason I had the reefangel controller. I implemented a Roberto Flow (check the forum) until Jabeo pump gave up. After that with 4 measurements, I was checking my ATO reservoir level, Sump at Return Pump, Sump at Skimmer and Return to Sump. It was just great. It will come with four 4" pvc pipes, you can cut them down or extend them using standard pvc pipes.
Onur
PostPosted: Tue Nov 29, 2022 3:19 pm
Interested in the wifi attachment.
PostPosted: Tue Nov 29, 2022 6:21 pm
I need to sell that with Bluetooth attachment as a set.
Onur
PostPosted: Tue Nov 29, 2022 8:34 pm
What does the bluetooth attachment do?
PostPosted: Tue Nov 29, 2022 8:36 pm
its not listed anywhere in the products section
PostPosted: Thu Dec 01, 2022 3:09 pm
Bluetooth attachment removes the need to use the usb to controller cable. You can program the controller (RA+) wirelessly. Roberto had some available, I don't think he mass produced them.
Onur
Return to Standard
Users browsing this forum: No registered users and 9 guests
