ATO saftey code
Smotz
ATO saftey code
Post by Smotz »
Can someone help me with this? I posted this in "How do I code?" but not getting much traffic there, I think.
I use the below code to override my ATO port if the water level is too high.
How can I get this to ignore feeding and water change mode? Not just during but for a few seconds after also so the water level stabilizes?
// just to be safe if the water level gets to 135 or greater, OVERRIDE the topoff.
   if ( ReefAngel.WaterLevel.GetLevel(1) >= 145 ) ReefAngel.Relay.Override (Topoff,0);
// End Main Top Off
Re: ATO saftey code
unsigned long atoIgnore=0;
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
atoIgnore=now();
if (now()-atoIgnore > 30) { // Wait 30 seconds before starting ATO
// End Main Top Off
Smotz
Re: ATO saftey code
Post by Smotz »
Thanks Lee - dumb question: in this example, are the {} needed?
  atoIgnore=now();
lnevo wrote:unsigned long atoIgnore=0;
atoIgnore=now();
// End Main Top Off
ATO saftey code
If you only have one command inside then no
