Memory Error
hous0067
Memory Error
Post by hous0067 »
Hi Guys,
RA Plus running the same code since July without issue until yesterday when I randomly noticed the heater was on when it shouldn't be (i.e. heater off temp < T3). I tried rebooting it, checking the memory settings, and even re-uploaded the code but it's ignoring the uploaded settings and continuing to act strange.
When I say ignoring, I changed the set points for the heater through the wizard but when I look at heater on and heater off temps through the android app it still has the old numbers. That in and of itself isn't a problem for me, but it's ignoring those temps, the relay stays on unless I change the setting through the app for the heater on and off to like 3...instead of 730 and 740 (i.e. 73.0 and 74.0 F)
Any ideas? Is the memory in the unit just cooked?
The code that was stable and running is below. Using the 1.1.3 Mac .dmg.
    ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port5Bit | Port6Bit;
    // Use T3 probe as temperature and overheat functions
    // Feeding and Water Change mode speed
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.StandardFan( Port3 );
    ReefAngel.ActinicLights( Port5 );
    ReefAngel.DayLights( Port6 );
    ReefAngel.Relay.DelayedOn( Port8 );
    ReefAngel.DCPump.LowATOChannel = None;
    ReefAngel.DCPump.HighATOChannel = AntiSync;
  // WP40 Night Mode
    // go to mode defined by RF memory locations
    if (hour()<InternalMemory.StdLightsOnHour_read() || hour()>InternalMemory.StdLightsOffHour_read())
      ReefAngel.DCPump.Duration=InternalMemory.RFDuration_read();
      ReefAngel.DCPump.Mode=InternalMemory.RFMode_read();
      ReefAngel.DCPump.Speed=InternalMemory.RFSpeed_read();
      else (ReefAngel.DCPump.UseMemory=true);
      //ato moonlight control
    pinMode(lowATOPin,OUTPUT);
    analogWrite(lowATOPin, 2.55*MoonPhase());
    ReefAngel.Portal( "hous0067" );
-Ken
Re: Memory Error
That is indeed odd.
If you change using app and then read it back, does it show the number you have saved prior to reading?
What about after rebooting, does it still show the number you saved?
hous0067
Re: Memory Error
Post by hous0067 »
Yeah, I can overwrite the values with the app. The numbers I write are the same ones it reads back. But, they aren't getting used or aren't getting used right. I have heater on temp at 730, heater off temp at 740, T3 is 76.4 and the heater port is on. I'm just relying on the heater's thermostat for now.
Yes, values I write from the app last through hard and soft boots.
-Ken
Re: Memory Error
Sorry for the confusion....
The master branch has a bug that was fixed on the dev branch.
StandardHeater is always using T1 on the libraries you are using.
Change your code from:
To this:
    ReefAngel.StandardHeater3( Port1 );
This will force it to use T3 and ignore the ReefAngel.TempProbe = T3_PROBE;
hous0067
Re: Memory Error
Post by hous0067 »
Compiler says, "no matching function" when I change that.
-Ken
Re: Memory Error
Ohh.... That function is also not in the master branch...
Try this:
ReefAngel.StandardHeater(T3_PROBE, Port1 ,InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());
