No longer can connect to upload code
benjy1234
Post by benjy1234 »
I have a macbook and the 1.0.43 plug in installed. When in web wizard it indicates that the plug in is found and connected but it posts an Error:404 whenever it connects. Also it will not detect the reef angel nor my wifi plug-in in the port.
Re: No longer can connect to upload code
Can you post a screenshot of the error? Are you using Chrome?
benjy1234
Post by benjy1234 »
I can post a screenshot when I get home but it just says Error: 404 in the lower section of the web wizard display. Other than that everything appears to be working minus the not connecting. I am using chrome.
benjy1234
Post by benjy1234 »
Attached is a screenshot of whats going on. No matter what I do I cant get the RA to communicate with computer
https://imgur.com/a/V95mmda
mav3rick478
Post by mav3rick478 »
Do you have the cloud attachment or just the normal wifi attachment? I've never been able to upload from the web wizard with just the wifi attachment.
Sent from my Pixel 4 XL using Tapatalk
benjy1234
Post by benjy1234 »
I have the cloud attachment. However I am unable to upload code to either the RA or the WIFI attachment. Im getting the same issue with both, the port is not recognizing that anything is plugged in.
