My RA Portal History is stuck on July 4
Related to the Portal
PostPosted: Mon Jul 31, 2023 8:42 pm
104.36.18.155
But I am doing a "new" set up with old equipment, so it could certainly be on my end.
I have updated the firmware in the wi-fi module and run the configuration script.
PostPosted: Mon Jul 31, 2023 8:57 pm
Hmmm. From my browser, it works if I use the URL (forum.reefangel.com) but not if I use the IP address. I'll reprogram the RA+ to use the URL.
Question: I have configured the wi-fi authentication. Does the Portal support that? I would think I'd need to give the portal the credentials somewhere... Maybe should try turning that off?
Dave
PostPosted: Mon Jul 31, 2023 9:51 pm
Ahhh.... that was it
Fixed now.
PostPosted: Mon Jul 31, 2023 10:01 pm
I connected to the wi-fi module via the USB to TTL cable. I added these 2 lines and saved.
set ip host 0.0.0.0
set dns name forum.reefangel.com
save
and everything on the portal works now!!!
Roberto, I think if you updated the web server's certificate it may have somehow configured the web server to only accept requests by name and not IP address??? Maybe the Let's Encrypt code did it?
PostPosted: Mon Jul 31, 2023 10:46 pm
Works now, only have graphs for an hour but at least it's working again, thanks everyone.
Sent from my Pixel 4 XL using Tapatalk
PostPosted: Tue Aug 01, 2023 4:00 pm
Works for me now too. Thanks everyone!
Jack
PostPosted: Wed Aug 02, 2023 4:48 pm
rimai wrote:Ahhh.... that was it
Fixed now.
Thank you. Great to have the data back!
Previous
Return to Portal
