I was looking into adding the relay charts to the U-App, and in doing so, I noticed that only charts for relays 1-3 appear to be working. Is this a known issue? Something specific to my configuration?
-Steve
Relay Charts Only Working for 1-3?
Re: Relay Charts Only Working for 1-3?
Just a little more info. When I hit the URL, I don't see any data beyond R3.
Are you using those boxes?
If you don't use it, there is no history to show.
What constitutes "using?" Do relays need to be turning on and off, and if so, within what timeframe? Seven days?
Or do I simply need to have them configured? They are definitely showing up on the portal, and I am actively using the first four of them.
I think I need to look deeper, though. I can actually see four of the relays on the chart, but if I hit the URL, I only seem to get data back for r1, r2, and r3.
This is what I'm hitting...
Has data:
http://forum.reefangel.com/status/jsonp ... callback=?
No data:
Has data:
No data:
You need one of the relays to be on at one point in time through the last 7 days
