Email Notifications not listed
Related to the Portal
Reefology
Post by Reefology »
Hi, hoping someone can please explain why my email notifications are not listed where I normally see them (see attached screenshot). I was getting notifications and when I went to adjust the temp and ph range, I noticed they were missing so I added them again and again and again... now I get several notifications at the same time. how do I see them? and delete all the duplicates?
thanks
Screen Shot 2020-03-27 at 12.28.14 PM.png (129.13 KiB) Viewed 6159 times
Re: Email Notifications not listed
There is a bug on the backend that if you use a comma in the description of the alert, it will generate an error and anything after that will not show. I deleted the ones with the comma. They should all be appearing now.
Reefology
Post by Reefology »
Excellent! thanks Roberto
jcjrogersstar
Post by jcjrogersstar »
Roberto, this must have happened to me as well. All of my notifications appear to be gone. Please fix.
I can see them.
Are you sure they are not there?
I can even see that some of them got triggered today.
jcjrogersstar
rimai wrote:I can see them.
Still not there.
Try again
jcjrogersstar
Fixed. Thanks!
jcjrogersstar
I don't know what I'm doing in the portal, but every time I add a trigger based on pH values, I lose everything. Please fix and let me know what to avoid to keep this from happening (I don't think I had a comma).
There is a bug on the backend that if you use the following, you have problems: , < > " and '
jcjrogersstar
rimai wrote:There is a bug on the backend that if you use the following, you have problems: , < > " and '
Only in the "description", right? You can use in the trigger (the name), correct?
I think on both.
jcjrogersstar
rimai wrote:I think on both.
Got it. Thanks.
