Text Alerts Stopped?
Hey All,
I've had my RA running rock solid for years and years. (I'd like to see the other guys claim that!) I ran into an issue recently that has me stumped. I no longer get text message alerts. I thought maybe AT&T changed something, but I sent a test email and it came right through. Do you think maybe AT&T has blocked emails coming from RA? Any ideas?
Re: Text Alerts Stopped?
Can you change the email address to a regular email instead of an email to sms bridge and see if you get that email?
Gave that a shot, didn't work either. Double checked in spam too.
Are you sure your wifi attachment is sending data to the portal?
I do not see any data for this username.
I can see it if I go to Portal. Haven't changed anything in ages, so it should be.
Yep. I can see history on my temp and pH too.
- Capture.PNG (241.89 KiB) Viewed 8041 times
I must have mistyped something.... I can see your data too... Sorry.
Can you add another trigger for like temperature of pH and see if the email is sent?
It could be something with the logic of the ATO flag... In which case, I would have to check it out.
Phew!
I added one for temp and it triggered, but no email. It is interesting that the ATO alert has not triggered for over a month. It should be going off right now.
- Capture.PNG (40.66 KiB) Viewed 8040 times
OK, let me check.
You are correct. It should have trigger according to your data...
Could you take another look please? They appear to have stopped working again....
It must be something else.
I have logs of alerts that were sent a few minutes ago (not for your username)
Let me dig up some more.
There must be something else not working as expected, because I do see the ATO flag in your log too, but no alert triggered...
I thought maybe it was just something with the text email address. It worked fine if I emailed it myself. Then thought maybe AT&T was blocking them from your server so I added another email address. Still no joy.
Sweet! I’ll let the ATO reservoir run dry and see if I get the alert.
