Portal Unreacheable address all of a sudden
Related to the Portal
howaboutme
Post by howaboutme »
Hi all,
A bit stumped here. All of a sudden, sometime last night, my controller is unreacheable. Neither the portal or the Android app can reach it. I restarted both the wifi attachment and the controller just to be sure, nothing. I double checked that my port forwarding was not inadvertently turn off, it's fine. The only clue I have is this error from the app:
Error 13: unexpected end of stream on http://howaboutme.tank-stats.com:2000/...
tank-stats is the domain I'm using from freedns.afraig.org.
any thoughts? thanks!
Edit: the wifi attachment has the green blinking light but it does not seem to show the flash of yellow/orange indicating data transfer to the portal.
Jack
howaboutme
Re: Portal Unreacheable address all of a sudden
Now getting this error code from the app:
Edit: It seems like the portals "last update" data changes seemingly indicating there are some updates happening even though it is still unreachable.
Also, wifi attachment has the slow blinking green light.
Where can I start to troubleshoot? Thanks.
Jack
howaboutme
NM. All good. It just solved itself.
Jack
