Stabilize PH probe
alexr54
Stabilize PH probe
Post by alexr54 »
Are there any tips or tricks I can use to stabilize the ph probe attached to the controller?
It started reading at 2.23Ph. My tank is healthy and if this were true everything would be dead quick.
It’s been at 2.23 for over a day now and is not budging. I’ve tried restarting and unplugging - replugging.
Seems I can’t get the probe to read correctly. Even when it’s working it’s quite low.
Any advice?
alexr54
Re: Stabilize PH probe
Post by alexr54 »
Seems no matter what I do I can’t get it to read correctly.
Now it’s at 1.80 while in the tank. It goes up when I take it out.
alexr54
Post by alexr54 »
Pic attached
alexr54
Post by alexr54 »
I just realized what’s wrong.
I have had absolutely no luck with several new parts I recently ordered.
The probe is faulty. The wire on top of the probe is causing the probe to not read ph. I need to mess with the wire to get it to read, but it is not stable.
This and the new temp probe is not working. No luck.
Fortunately the new salinity probe is working fine.
I have a new Ph expansion with probe on order. I hope that works good.
What can I do to get a replacement ph and temp probe for the faulty ones?
Sent you a pm
alexr54
Post by alexr54 »
rimai wrote:Sent you a pm
Thank you very much!!
