Salinity temp compensation?
PostPosted: Thu Aug 15, 2013 9:50 am
rimai wrote:Yes, needs to be calibrated at 35ppt and you can't change it :(
If you want to create a FlexibleSalinityCalibration() function ;), maybe others could benefit from it too :)
Maybe. I will see. :)
It seems like I don't even have enough time to get stuff done that I "need" to get done.
PostPosted: Mon Aug 26, 2013 2:41 am
rimai wrote:When you enable the compensation, you should recalibrate.
It will store the temperature in which the calibration happened in the internal memory and use it as reference.
To enable compensation and use the default alpha value, use this:
ReefAngel.Salinity.SetCompensation(0);
Quick question, where to I place this in my code - in the initialisation or loop? Sorry if a silly question!
Cheers..
PostPosted: Mon Aug 26, 2013 8:11 am
setup()
PostPosted: Fri Feb 12, 2021 3:07 pm
hi all,
bumping this thread.
can someone confirm that this code is all that's needed (other than recalibrate) to enable temp compensation for salinity?
I'm trying to follow the initial developments in this thread but at the end it does look like the above is it?
Jack
PostPosted: Fri Feb 12, 2021 3:11 pm
That is it.
PostPosted: Fri Feb 12, 2021 3:22 pm
rimai wrote:That is it.
thanks!
Jack
Previous
Return to Addons
