Dosing Pump Power
Dosing Pump Power
I've got 3 RA Dosing pumps. I've noticed that they have power plugs on both sides of the device. On one side though, there's a power switch and the other side doesn't have one.
My question is: Does the power switch control the power coming in to both ports or just to the side that its on?
I'm guessing it only controls power to the port on the same side.
I haven't tested this out yet (haven't had a chance to) and wanted to ask for confirmation.
EDIT: I just tested and it appears that the power switch controls power to the pump no matter what port/plug is used on the pump.
If someone else could confirm that to me, it would be appreciated. Thanks :)
Re: Dosing Pump Power
Yeah, it is just so you can Daisy chain if you want to.
cool. that's an interesting idea of being able to daisy chain them.
