dosing pump hose barb
Posted: Sat May 23, 2020 9:31 am
by binder
the dosing pumps come with small hose barbs. what are their sizes? and where can I get replacement ones? I don't need replacements currently but you never know.
Re: dosing pump hose barb
Posted: Sun May 24, 2020 9:06 am
The tubing is 0.15" OD.
If you ever need some, just send me a pm.
Posted: Sun May 24, 2020 2:30 pm
by binder
rimai wrote:The tubing is 0.15" OD.
ok. good to know. thanks.
btw, when will you be getting the dosing pumps back in stock?
Posted: Mon May 25, 2020 7:33 am
I am considering removing that.
Posted: Mon May 25, 2020 8:37 am
by binder
rimai wrote:I am considering removing that.
removing the out of stock or removing the pumps?
Posted: Mon May 25, 2020 1:06 pm
Removing the pumps.
Posted: Mon May 25, 2020 2:08 pm
by binder
rimai wrote:Removing the pumps.
ahhhh. well, I would understand if you did.
I would be up for purchasing 1 or 2 more from you if you had any. plus depending on how long the pump heads last, I may want to consider getting some extra if you had those. in case you do discontinue them so I wouldn't be out of luck and have to replace the entire pump.
I'm just trying to support you for all your hard work and efforts. If you don't have any pumps, it's no biggie.
thanks!
