Star and multi-water level support
Posted: Fri Oct 25, 2019 12:49 pm
by binder
I've got a multi water level expansion module and I have a Star. For whatever reason, the star only shows the standard WL on the display and not the extra 4 ports (WL1 - WL4). I do not believe it's even sending the data out when requested (my app queries the /r99 and no values come through for the WL1 - WL4 ports). I calibrated WL1 and I know the port works and module works because it returned values during the calibration (600+ for the regular and 1100+ for the full/submerged).
Looking at the /r99 output, it's not even registering that the water multi-level expansion module is present. It's just showing the standard WL. I do not recall from the past if we have to do anything extra/special to bring in the multi-level support. I didn't think we did because my app cannot distinguish between the single channel and multi-channel modules.
I have not dove into the code yet to find out if there's a problem. I wanted to post first and see if anyone else has encountered or noticed anything as well.
Re: Star and multi-water level support
Posted: Fri Oct 25, 2019 6:39 pm
ReefAngel.AddMultiChannelWaterLevelExpansion(); // MultiChannelWaterLevelExpansion
That should take care of it :)
Posted: Sat Oct 26, 2019 6:33 am
by binder
of course it would be something that obvious and simple.
