Enter them into the Portal, then "Download Labels from Portal" in the Uapp menu.How can I get my labels onto the U app?
Universal App
Re: Universal App
Re: Universal App
I've been trying to get into the portal but my new Mesh system wont allow me to forward the port . I got rid of my ISP gateway and bought my own and a mesh router system so something is not working.Inside the router it is set up to have 2000 open but it's just not physically open on the reserved IP address of the RA.
I'm going to have to find my old router or something ,Been on with netgear support and they had me do everything I already had done and the conclusion by them was "It should be working" with no resolution other than it must be your internet company.. .
I wish I could get into the portal without port forwarding. I need to try to figure out a way to temporarily get a port forwarded or something.
Re: Universal App
Just to change the labels, you don't need to get port forwarding setup.
Why do you want to get the portal connected to your controller with port forwarding?
Re: Universal App
Whenever I click on the labels or Portal settings it just clicks me to the top of the page .rimai wrote:Just to change the labels, you don't need to get port forwarding setup.
I don't seem to have any option to click on any of the options . When I click on it it brings me up to show the top of the page like where the user control panel is and says an error occurred .The way to adjust is to just click on the area I have circled right?
Can you delete the portal info for my acct and let me start from scratch?
Can I literally start a new username and just go from there?
I tried it on two seperate computers just now and still same.
Also Google is saying the time cert for the website is unsafe or something ? My phone did it earlier and now both my laptops I had to bypass and proceed anyway .
- Portal setting.PNG (32.31 KiB) Viewed 14141 times
Re: Universal App
I made a change to the portal page.
Try again.
You may need to reload the page by holding shift while clicking the refresh icon.
I also fixed the issue with the certificate expired.
Try again.
Re: Universal App
I have Uapp on iPhone 10. What do I need to enter in the app settings to make this work? My login works in the portal and I have tested that my port is "open". The Uapp status tab reads "Cloud status: Disconnected" "Current mode: Nominal"
Re: Universal App
RA+.. I see my profile shows I joined in 2013 so that is when I purchased my equipment..
Re: Universal App
Cloud feature is only available with RA* or with the cloud wifi attachment.
So, on Uapp, you enter the IP address and port and leave the cloud username and password blank.
Re: Universal App
Yes I have done that and still get no response on the "status" page. If I try to press a function like "clear ATO" I get "unable to process controller data!". I have the android app on an old tablet with the same IP and Port data entered and it works fine.
Re: Universal App
Try deleting the profile and creating a new one and make sure that you do not type anything on the cloud section. You may also need to use the Uapp without the ssl.
http://forum.reefangel.com/uapp
Re: Universal App
Thank you. I used the link you provided - entered my IP and port -and it worked.
Re: Universal App
rimai wrote:I made a change to the portal page.
Try again.
Thanks I'll get in this again. So please disregard the PM I just sent lol. I need to turn on the notification for forum replies.. Happy holidays everyone..
Re: Universal App
So I got it all working again( thanks for adjusting the portal ) but for some reason just in the U App webpage it won't list the main relay . It has expansion 1&2?
Got the labels fixed on the portal but the main relay labels are not there and exp 2 controls the main relay ?
Also no matter how many times I upload from wizard it has my expansion relay(older style )as the fist relay not the newer one from the *?
I think something is compiling wrong as it thinks I have two expansion relays when I only have one. I can control /toggle the relays but it's off by a full 8outlets ?
Edit : I just named the outlets for exp 1&2 to transfer them to the U APP.. work around is fine but weird how I can't see main relay and unable to just have the newer relay as the "Main".
Noticed the head unit doesn't save /Display the correct date and time after a reboot. Does this just take a bit ?
I tried not choosing expansion module etc all the same.
How do I get the main relay to show on the U APP? It's accurate on the portal I just can't control them due to port forwarding.
Re: Universal App
Could you check new version of app please. When I install app it gives me screen as on picture. All buttons are non responsive.
- Screenshot_2024-03-02-09-33-09-631_com.android.chrome.jpg (71.82 KiB) Viewed 1343 times
