ESP8266 Custom Wifi Attachment
Posted: Fri May 12, 2017 1:20 am
by v01d
Good day,
I have written some code to use an ESP8266 as a custom wifi attachment for the RA.
I can't find the code for the existing official wifi attachment, I assume it's not open?
There are a few other questions I have that could help improve the functionality of this custom code if this kind of thing isn't frowned upon :-)
Regards,
Nevar
Re: ESP8266 Custom Wifi Attachment
Posted: Fri May 12, 2017 8:39 am
The original WiFi attachment doesn't require any code. It is a pure hardware solution. The cloud WiFi attachment is open source and uses ATSAM25 chip. Use the web wizard to see the code.
I would love to see what you can come up with and may even be able to help too :)
Posted: Sat May 13, 2017 6:04 am
awesome! this could be great. I'm curious as well.
Posted: Mon May 15, 2017 1:09 am
by v01d
Great, as I mentioned, I've already written code that I'm currently using with the ESP8266, but I would like to go through the cloud wifi code to optimise my communication with the RA. As I didn't think of looking at the cloud wifi code, my code may be terrible, but it works lol. Eg. I was trying to add security for /wifi and make sure the forum user and portalkey is used, but decided to just check the IP. You can view the current code on my github account v01d-cypher/ReefAngel_ESP8266
Posted: Sat Aug 05, 2017 6:29 pm
The cloud wifi attachment rev 2 uses ESP8266.
The ATSAMW25 wasn't as stable as I had imagined.
Posted: Sat Mar 07, 2020 3:35 am
by edisonvs
Hi to all,
Is v2 with esp8266 open source too?
It will cost me more than 200$ to buy new cloud attachment. That is way too expensive for me.
Is there way to open source this?
Posted: Mon Mar 09, 2020 10:05 pm
I do, but it is an old code.
You may need to change and update it to compile with more updated libraries.
#include <FS.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <ESP8266httpUpdate.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <Ticker.h>
// solid green - factory reset
// blink green - connecting wifi
// blink blue - configuration required (SoftAP)
// blink magenta - connecting to cloud server
// solid cyan - connected to cloud server
// blinking cyan - transmitting/receiving data
// solid yellow - firmware update
#define LED_GREEN 0
#define LED_BLUE 4
#define LED_RED 5
#define RESET_ALL 16
#define ENABLE_DEBUG 12
#define version "1.0.0"
#define PortalServer "forum.reefangel.com"
#define MQTTServer "cloud.reefangel.com"
#define MQTTPORT 1883 // MQTT server port
WiFiManager wifiManager;
WiFiServer server(2000);
WiFiClient webclient;
WiFiClient portalclient;
WiFiClient espClient;
PubSubClient CloudClient(espClient);
Ticker ticker;
long lastMsg = 0;
char msg[50];
int value = 0;
boolean LED_status = false;
boolean first_connection = true;
boolean sending_data = false;
boolean data_ready = false;
boolean PortalConnection = false;
boolean shouldSaveConfig = false;
boolean updating = false;
boolean debug_log = false;
unsigned long cloudmillis = millis();
unsigned long client_timeout = millis();
unsigned long serial_timeout = millis();
String currentLine = "";                // make a String to hold incoming data from the client
char mqtt_username[32];
char mqtt_password[32];
// Function prototypes
void SendData();
void callback(char* topic, byte* payload, unsigned int length);
void reconnect();
void saveConfigCallback ();
void configModeCallback (WiFiManager *myWiFiManager);
void WifiCheckCallback ();
void APtick();
void Wifitick();
void Cloudtick();
void Datatick();
void print_debug(String value);
void println_debug(String value);
void LED_Color(int Red, int Green, int Blue);
void setup() {
  pinMode(LED_GREEN, OUTPUT);
  pinMode(LED_BLUE, OUTPUT);
  pinMode(LED_RED, OUTPUT);
  digitalWrite(LED_GREEN, LOW);
  digitalWrite(LED_BLUE, HIGH);
  digitalWrite(LED_RED, HIGH);
  wifi_station_set_hostname( "ReefAngelCloudWifi" );
  Serial.begin(57600);
  Serial.setRxBufferSize(2048);
  pinMode(RESET_ALL, INPUT);
  digitalWrite(RESET_ALL, HIGH);
  pinMode(ENABLE_DEBUG, INPUT);
  digitalWrite(ENABLE_DEBUG, HIGH);
  EEPROM.begin(512);
  if (digitalRead(ENABLE_DEBUG) == LOW)
    wifiManager.setDebugOutput(true);
    debug_log = true;
    wifiManager.setDebugOutput(false);
    debug_log = false;
  //  wifiManager.setDebugOutput(true);
  //  debug_log=true;
  println_debug("");
  print_debug("Current version: ");
  println_debug(version);
  if (digitalRead(RESET_ALL) == LOW)
    //    updating=true;
    println_debug("Resetting");
    EEPROM.write(256, 0);
    EEPROM.commit();
    ESP.reset();
    while (1);
  wifiManager.setVersion(version);
  if (EEPROM.read(256) != 1)
    wifiManager.resetSettings();
    SPIFFS.format();
    EEPROM.write(256, 1);
    EEPROM.commit();
  if (SPIFFS.begin()) {
    println_debug("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      println_debug("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        println_debug("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        if (debug_log) json.printTo(Serial);
        if (json.success()) {
          println_debug("\nparsed json");
          strcpy(mqtt_username, json["mqtt_username"]);
          strcpy(mqtt_password, json["mqtt_password"]);
        } else {
          println_debug("failed to load json config");
  } else {
    println_debug("failed to mount FS");
  WiFiManagerParameter custom_mqtt_username("Cloud Username", "Cloud Username", mqtt_username, 40);
  WiFiManagerParameter custom_mqtt_password("Cloud Password", "Cloud Password", mqtt_password, 40);
  wifiManager.addParameter(&custom_mqtt_username);
  wifiManager.addParameter(&custom_mqtt_password);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.setAPCallback(configModeCallback);
  wifiManager.setCheckWifiCallback(WifiCheckCallback);
  LED_Color(0, 0, 0);
  ticker.attach(0.5, Wifitick);
  wifiManager.autoConnect("ReefAngelCloudWifi");
  ticker.detach();
  LED_Color(900, 0, 1023);
  server.begin();
  CloudClient.setServer(MQTTServer, MQTTPORT);
  CloudClient.setCallback(callback);
  strcpy(mqtt_username, custom_mqtt_username.getValue());
  strcpy(mqtt_password, custom_mqtt_password.getValue());
  print_debug("username: ");
  println_debug(mqtt_username);
  print_debug("password: ");
  println_debug(mqtt_password);
  if (shouldSaveConfig) {
    println_debug("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["mqtt_username"] = mqtt_username;
    json["mqtt_password"] = mqtt_password;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      println_debug("failed to open config file for writing");
    println_debug("");
    json.printTo(configFile);
    configFile.close();
    //end save
  print_debug("IP address: ");
  if (debug_log) Serial.println(WiFi.localIP());
void loop() {
  if ((digitalRead(RESET_ALL) == LOW) && !updating)
    if (WiFi.status() == WL_CONNECTED)
      updating = true;
      ticker.detach();
      LED_Color(1023, 900, 0);
      println_debug("Updating...");
      ESPhttpUpdate.update("forum.reefangel.com", 80, "/firmware/CloudWifiESP8266Attachment.ino.bin");
      EEPROM.commit();
      ESP.reset();
      while (1);
  if (!CloudClient.connected() && (((millis() - cloudmillis) > 30000) || first_connection)) {
    first_connection = false;
    LED_Color(0, 0, 0);
    ticker.detach();
    ticker.attach(0.5, Cloudtick);
    reconnect();
  CloudClient.loop();
  webclient = server.available();
  if (webclient) {                             // if you get a client,
    LED_Color(0, 0, 0);
    ticker.detach();
    ticker.attach(0.05, Datatick);
    println_debug("new incoming client");           // print a message out the serial port
    while (webclient.connected()) {            // loop while the client's connected
      if (millis() - client_timeout > 2000)
        println_debug("incoming client timeout");           // print a message out the serial port
        webclient.stop();
        LED_Color(0, 1023, 1023);
        ticker.detach();
      if (!sending_data)
        while (webclient.available()) {             // if there's bytes to read from the client,
          char c = webclient.read();             // read a byte, then
          Serial.write(c);                    // print it out the serial monitor
      while (Serial.available())
        sending_data = true;
        char c = Serial.read();
        currentLine += c;
        if (c == 13) SendData();
        //        if (currentLine.length() == 255) {
        //          SendData();
      if (millis() - serial_timeout > 400)
        if (currentLine.length() > 0) {
          SendData();
          //webclient.println();
          delay(1000);
    // close the connection:
    webclient.stop();
    ticker.detach();
    println_debug("incoming client disconnected");
      currentLine += c;
      if (c == 10) data_ready = true;
      if (millis() - serial_timeout > 200 || data_ready)
          data_ready = false;
          if (currentLine.startsWith("GET"))
            PortalConnection = true;
            println_debug("Connecting to Portal Server");
            LED_Color(0, 0, 0);
            ticker.detach();
            if (portalclient.connect(PortalServer, 80)) {
              println_debug("Connected");
              // Make a HTTP request:
              portalclient.print(currentLine);
              portalclient.println(F(" HTTP/1.1"));
              portalclient.println(F("Host: forum.reefangel.com"));
              portalclient.println(F("Connection: close"));
              portalclient.println();
              println_debug("Failed to connect");
              ticker.detach();
          if (currentLine.startsWith("CLOUD:"))
            //Serial.print(currentLine);
            if (currentLine.length() < 32)
              if (CloudClient.connected())
                println_debug("Publishing ");
                currentLine.replace("CLOUD:", "");
                println_debug(currentLine);
                char pub_buffer[sizeof(mqtt_username) + 5];
                sprintf(pub_buffer, "%s/out", mqtt_username);
                //println_debug(pub_buffer);
                char pub_msg[currentLine.length() + 1];
                currentLine.toCharArray(pub_msg, currentLine.length() + 1);
                CloudClient.publish(pub_buffer, pub_msg);
              //Serial.print(F("Error on incoming data: "));
              //Serial.println(currentLine.length());
          currentLine = "";
    while (portalclient.available()) {
      char c = portalclient.read();
      //      Serial.write(c);
    if (PortalConnection && !portalclient.connected()) {
      //      Serial.println();
      println_debug("Disconnecting from Portal Server");
      portalclient.stop();
      ticker.detach();
void SendData()
  //  Serial.print(currentLine);
  webclient.print(currentLine);
  Serial.println(currentLine);
  currentLine = "";
//void setup_wifi() {
//  delay(10);
//  // We start by connecting to a WiFi network
//  Serial.print(F("Connecting to "));
//  Serial.println(WIFI_SSID);
//  WiFi.begin(WIFI_SSID, WIFI_PASS);
//  while (WiFi.status() != WL_CONNECTED) {
//    delay(500);
//    Serial.print(".");
//  digitalWrite(LED_GREEN,HIGH);
//  Serial.println("");
//  Serial.println(F("WiFi connected"));
//  Serial.print(F("IP address: "));
//  Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("cloud:");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.print(" ");
void reconnect() {
  // Loop until we're reconnected
  if (!CloudClient.connected()) {
    //    Serial.print(F("Username: "));
    //    Serial.println(CLOUD_USERNAME);
    println_debug("Connecting to cloud server...");
    // Attempt to connect
    char sub_buffer[sizeof(mqtt_username) + 6];
    sprintf(sub_buffer, "RA-%s", mqtt_username);
    //Serial.println(sub_buffer);
    if (CloudClient.connect(sub_buffer, mqtt_username, mqtt_password)) {
      // Once connected, publish an announcement...
      sprintf(sub_buffer, "%s/in/#", mqtt_username);
      print_debug("Subscribing to ");
      println_debug(sub_buffer);
      CloudClient.subscribe(sub_buffer);
      ticker.detach();
      //Serial.swap();
    } else {
      print_debug("Failed, rc=");
      if (debug_log) Serial.print(CloudClient.state());
      println_debug(" try again in 30 seconds");
void saveConfigCallback () {
  println_debug("Should save config");
  shouldSaveConfig = true;
void configModeCallback (WiFiManager *myWiFiManager) {
  LED_Color(0, 0, 0);
  ticker.detach();
  println_debug("Entered config mode");
  WiFi.softAPIP();
  ticker.attach(0.5, APtick);
void WifiCheckCallback () {
  WiFi.softAPdisconnect(true);
  LED_Color(0, 0, 0);
  ticker.detach();
  println_debug("Checking Wifi Credentials");
void APtick()
  //toggle state
  int state = digitalRead(LED_BLUE);  // get the current state of GPIO1 pin
  digitalWrite(LED_BLUE, !state);     // set pin to the opposite state
void Wifitick()
  //toggle state
  int state = digitalRead(LED_GREEN);  // get the current state of GPIO1 pin
  digitalWrite(LED_GREEN, !state);     // set pin to the opposite state
void Cloudtick()
  //toggle state
  digitalWrite(LED_RED, !state);     // set pin to the opposite state
void Datatick()
  //toggle state
  if (debug_log)
    Serial.print(value);
  if (debug_log)
    Serial.println(value);
  analogWrite(LED_RED, 1023 - Red);
  analogWrite(LED_GREEN, 1023 - Green);
  analogWrite(LED_BLUE, 1023 - Blue);
Posted: Tue Mar 10, 2020 12:30 am
by edisonvs
Thank you very much Rimai!
Posted: Fri Feb 02, 2024 9:53 am
by edisonvs
Hello, could you please share new code since now we need to update the cloud attachment. I have download bin from old code ota link, but that not working on my esp.
Posted: Fri Feb 02, 2024 3:30 pm
by brennyn21
sorry for the delay here is the correct code for the cloud wifi attachment!
#include <FS.h>
#include <EEPROM.h>
#include <Ticker.h>
#define LED_GREEN 0
#define LED_BLUE 4
#define LED_RED 5
#define version "1.0.2"
#define MQTTServer "forum.reefangel.com"
Ticker ticker;
long lastMsg = 0;
char msg[50];
int value = 0;
void SendData();
void reconnect();
void APtick();
void Wifitick();
void Cloudtick();
void Datatick();
void setup() {
  EEPROM.begin(512);
    debug_log = true;
    debug_log = false;
  //  debug_log=true;
  println_debug("");
    //    updating=true;
    EEPROM.commit();
    ESP.reset();
    while (1);
  if (EEPROM.read(128) != 1)
    SPIFFS.format();
    EEPROM.write(128, 1);
    EEPROM.commit();
    Serial.println("mounted file system");
      Serial.println("reading config file");
      if (configFile) {
        Serial.println("opened config file");
          Serial.println("\nparsed json");
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  LED_Color(0, 0, 0);
  ticker.detach();
   Serial.print("username: ");
  Serial.println(mqtt_username);
    Serial.print("password: ");
    Serial.println(mqtt_password);
    Serial.println("saving config");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    Serial.println("");
    configFile.close();
    //end save
void loop() {
      updating = true;
      ticker.detach();
      EEPROM.commit();
      ESP.reset();
      while (1);
    LED_Color(0, 0, 0);
    ticker.detach();
    reconnect();
  CloudClient.loop();
    LED_Color(0, 0, 0);
    ticker.detach();
        webclient.stop();
        ticker.detach();
      if (!sending_data)
        currentLine += c;
        //          SendData();
          SendData();
          delay(1000);
    webclient.stop();
    ticker.detach();
      currentLine += c;
          data_ready = false;
          if (currentLine.startsWith("GET")) {
    LED_Color(0, 0, 0);
    ticker.detach();
    if (portalclient.connect(PortalServer, 3000)) {
        // Log the request being sent
        println_debug("Sending Request:");
        portalclient.println(currentLine);
        portalclient.println(F(" HTTP/1.1\r\n"));
        portalclient.println(F("Host: reefangel.com\r\n"));
        portalclient.println(F("Connection: close\r\n"));
    } else {
        ticker.detach();
          currentLine = "";
      //      Serial.write(c);
      ticker.detach();
    if (portalclient.connected()) {
    println_debug("Response from the server:");
    // Wait for data from the server
    while (portalclient.connected() || portalclient.available()) {
        if (portalclient.available()) {
            String line = portalclient.readStringUntil('\r');
            println_debug(line);
    println_debug("Server connection closed");
void SendData()
  currentLine = "";
//  delay(10);
//    delay(500);
  Serial.print(" ");
void reconnect() {
      ticker.detach();
      //Serial.swap();
    } else {
  LED_Color(0, 0, 0);
  ticker.detach();
  WiFi.softAPIP();
  LED_Color(0, 0, 0);
  ticker.detach();
void APtick()
  //toggle state
void Wifitick()
  //toggle state
void Cloudtick()
  //toggle state
void Datatick()
  //toggle state
  if (debug_log)
  if (debug_log)
Posted: Sat Feb 03, 2024 4:32 am
by edisonvs
Thank you very much. Hope this will also help all others that use mqtt for integrating in Homeassistant.
