Analog Dimming & MOONPHASE ?
CASPAR
I have the RA + Analog and wish to have my moonlights dim or say work with moonphase this is my code could someone check it, it shows PWM just would like to run moonlights on the Actinic dimming side and overheat buzzer off of Daylight side created this code in Wizard mode in Arduino 1.0 here is code:
byte buzzer=0;
byte overheatflag=0;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port3,11,0,19,0 );
ReefAngel.StandardLights( Port4,13,0,17,0 );
ReefAngel.StandardHeater( Port5,782,785 );
ReefAngel.StandardFan( Port6,780,785 );
ReefAngel.StandardLights( Port8,19,0,11,0 );
buzzer = overheatflag;
if ( buzzer > 1 ) buzzer = 100;
ReefAngel.PWM.SetDaylight( buzzer );
ReefAngel.Portal( "CASPAR" );
byte buzzer=0;
CASPAR
Re: Analog Dimming & MOONPHASE ?
Ok moonlight seems to be working plugged into actinic side but can not get buzzer to work off of daylight side for over heat alarm..........Any ideas?
CASPAR
Ok thanks and noticed when using moonphase webpage portal shows actinic at 32% anything lower than that and moonlight goes completly out change dates on pc then change date on RA to match and moonlight seems to increase with phase of moon as should, but when their is say a quarter moon led moonlight goes totally out when actinic side is saying say 30% And buzzer side set up on daylight side shows hardly no voltage output to even power the buzzer at a known high temp.
You just found the first bug on the Wizard
For the buzzer to work, replace this:
With this:
I'll update the Wizard to fix this bug.
The moonlights were designed to dim properly on the PWM signal.
On analog, there is a cut off point that you are experiencing.
It looks like you don't really need the analog signal. If you are interested on exchanging it for a PWM signal, simply PM me.
if ( buzzer > 1 ) buzzer = 100;Code: Select all
if ( buzzer >= 1 ) buzzer = 100;The moonlights were designed to dim properly on the PWM signal.
- DrewPalmer04
How would I do a moon phase when my two dimming channels are already used for analog meanwell drivers? I don't need fancy just a possibility to have some LEDs that follow the moon cycle. ATO ports on head unit impossible to use? I assume they don't dim. Only switch? Options?
It is possible, but the ATO port is not boosted and will only output 5VDC.
The other option would be a dimming expansion module.
Blawson
With that said about the ato port, does that mean plugging in an ai nano will never get 100%
AI uses different technology.
Those fixtures use serial communication and they have an independent controller inside the fixture.
That's why you can control all 3 channels with just a pair of wires.
- DrewPalmer04
The code needed to make the ATO ports to go 0-5v with moon phase? That would suit me.
You can use the low ATO port.
What you need is this:
That will make the low ATO port to output 0-5V according to the moon cycle.
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,(int)MoonPhase()*2.55);
- DrewPalmer04
Thanks Roberto...now just to order more dimmer connectors.
lol AND temp probes...andddd....never ending
- DrewPalmer04
where should this code be placed? After I placed in the software and uploaded my PWM values are even...and that's not how I have it programmed.
// Autogenerated file by RAGen (v1.2.2.171), (05/29/2012 16:15)
// RA_052912_1615.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardLights( Port1,19,0,6,30 );
ReefAngel.StandardHeater( Port4,740,770 );
ReefAngel.StandardLights( Port7,6,0,20,0 );
ReefAngel.StandardLights( Port8,7,0,19,0 );
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
ReefAngel.Portal("DrewPalmer04", "********");
- DrewPalmer04
Better?
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
- DrewPalmer04
THANKS!
Will I need to deal with polarity? Which is (+)?
Yeah, you need to watch polarity.
They have the same polarity as the standard PWM channels.
- DrewPalmer04
got it thanks!
- DrewPalmer04
I've got the moonlights wired in. I'm experiencing a pulse every 5-8 seconds? It's a millisecond probably, but this is a weird thing that is happening?
Ideas?
Ideas?
Are you using StandardATO? or SingleATO that uses the low port?
- DrewPalmer04
Please clarify?
I have a string of LEDs on the low port with proper polarity. I single connector going ONLY to the low ATO port.
I meant if in your code you are using any ATO function.
Can you paste the code?
- DrewPalmer04
I've not modified anything related to ATO. I would assume its standardATO
That's probably the reason.
The StandardATO is querying that port to check for the float switch and interfering with the dimming.
- DrewPalmer04
Makes perfect sense. How do I change that code? Also how do I view my existing code without saving my custom code and uploading the total code again?
There is no way to reverse back what you have inside the RA already.
The best practice is to save the code with a filename that is easy for you to remember and open the file when you need to make changes.
- DrewPalmer04
Ok that's what I've been doing. That's good. So how do I go from standard to singleATO?
Instead of using StandardATO, you need to use SingleATOHigh
- DrewPalmer04
Thanks. I'm sure I'll figure it out
