can't even get my pump to turn on!
mineman@mac.com
Post by mineman@mac.com »
Thank God the tank isn't completely filled yet!
First off, let me tell you that I finally got this thing working correctly on my 55 when I decided to do an upgrade to a 120. I am using the iPhone app which at this point is the only way I can control most of the tank (manually). I thought I was figuring this thing out but now I'm as lost as the day I bought it. :( At this point, here is what I want it to do:
Relay 1: ATO I have it on low so because I am using an aqualifter
Relay 2: Skimmer (off during feeding)
Relay 3: Lights (not ready to get creative with them yet!)
Relay 4: Pump (I might just move this to a constant 110v)
Relay 5: Wavemaker (I am using an eternal controller but want it turned off during water changes and feeding)
Relay 6: Standard heater (on 79.1; off 80)
Relay 7: Dose pump (one second twice a day, off during feeding and water change)
Relay 8: Dose pump (one second twice a day, off during feeding and water change)
I will need to modify this eventually so if all notes would be appreciated! Here are my codes>
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.MHOnHour_write(0);
    InternalMemory.MHOffHour_write(0);
    InternalMemory.MHDelay_write(0);
    InternalMemory.StdLightsOnHour_write(15);
    InternalMemory.StdLightsOnMinute_write(30);
    InternalMemory.StdLightsOffHour_write(20);
    InternalMemory.StdLightsOffMinute_write(30);
    InternalMemory.DP1Timer_write(4);
    InternalMemory.DP2Timer_write(4);
    InternalMemory.ATOTimeout_write(255);
    InternalMemory.ATOHighTimeout_write(60);
    InternalMemory.LEDPWMActinic_write(100);
    InternalMemory.LEDPWMDaylight_write(100);
    InternalMemory.WM1Timer_write(0);
    InternalMemory.WM2Timer_write(0);
    InternalMemory.HeaterTempOn_write(791);
    InternalMemory.HeaterTempOff_write(800);
    InternalMemory.ChillerTempOn_write(774);
    InternalMemory.ChillerTempOff_write(770);
    InternalMemory.PHMax_write(830);
    InternalMemory.PHMin_write(540);
    InternalMemory.RFMode_write(Constant);
    InternalMemory.RFSpeed_write(140);
    InternalMemory.RFDuration_write(8);
    InternalMemory.PWMSlopeEndD_write(100);
    InternalMemory.PWMSlopeEndA_write(100);
    InternalMemory.IMCheck_write(0x5241494D);
    // display the values
    char buf[128];
    sprintf(buf, "MH %2d:%02d-%2d:%02d,%d", InternalMemory.MHOnHour_read(), InternalMemory.MHOnMinute_read(),
                                         InternalMemory.MHOffHour_read(), InternalMemory.MHOffMinute_read(),
                                         InternalMemory.MHDelay_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW, buf);
    sprintf(buf, "Std %2d:%02d-%2d:%02d", InternalMemory.StdLightsOnHour_read(), InternalMemory.StdLightsOnMinute_read(),
                                          InternalMemory.StdLightsOffHour_read(), InternalMemory.StdLightsOffMinute_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, buf);
    sprintf(buf, "LED A: %d%% D: %d%%", InternalMemory.LEDPWMActinic_read(), InternalMemory.LEDPWMDaylight_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*3, buf);
    sprintf(buf, "WM1: %ds", InternalMemory.WM1Timer_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, buf);
    sprintf(buf, "WM2: %ds", InternalMemory.WM2Timer_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, buf);
    sprintf(buf, "F: %ds", InternalMemory.FeedingTimer_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*6, buf);
    sprintf(buf, "S: %ds", InternalMemory.LCDTimer_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*7, buf);
    sprintf(buf, "H On: %d -> %d", InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*9, buf);
    sprintf(buf, "C On: %d -> %d", InternalMemory.ChillerTempOn_read(), InternalMemory.ChillerTempOff_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*10, buf);
    sprintf(buf, "PH %d - %d", InternalMemory.PHMax_read(), InternalMemory.PHMin_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*11, buf);
    delay(10000);
    sprintf(buf, "OH: %dF", InternalMemory.OverheatTemp_read());
    sprintf(buf, "ATO L: %ds (%dh)", InternalMemory.ATOTimeout_read(), InternalMemory.ATOHourInterval_read());
    sprintf(buf, "ATO H: %ds (%dh)", InternalMemory.ATOHighTimeout_read(), InternalMemory.ATOHighHourInterval_read());
    sprintf(buf, "DP1: %2d:%02d", InternalMemory.DP1OnHour_read(), InternalMemory.DP1OnMinute_read());
    sprintf(buf, "     %ds", InternalMemory.DP1Timer_read());
    sprintf(buf, "DP2: %2d:%02d", InternalMemory.DP2OnHour_read(), InternalMemory.DP2OnMinute_read());
    sprintf(buf, "     %ds", InternalMemory.DP2Timer_read());
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*8, buf);
    delay(10000);
[code]
and
[code]#include <ReefAngel_Features.h>
{// Starting from the left, it's Ports 87654321;
  ReefAngel.FeedingModePorts = B01001011;
  ReefAngel.WaterChangePorts = B10110011;
  ReefAngel.SingleATOLow(Port1);
  ReefAngel.StandardLights(Port3);
  ReefAngel.Wavemaker1(Port5);
  ReefAngel.StandardHeater(Port6);
    if (now()%43200<1) ReefAngel.Relay.On(Port7);
  else ReefAngel.Relay.Off(Port7);
    if (now()%43200<1) ReefAngel.Relay.On(Port8);
  else ReefAngel.Relay.Off(Port8);
  // You can only increment the dosing in seconds
  // 43200 the frequency in seconds that the dosing pump will be activated. 24hrs= 86400s, 12hrs= 43200s
  // 1 is the number of seconds that the dosing pump will stay on.
  ReefAngel.Portal("mineman@mac.com");
[code]
rossbryant1956
Re: can't even get my pump to turn on!
Post by rossbryant1956 »
I guess the one thing I am doing separately from you is taking things one device at at time. I started with pump and heaters; added lights, and stopped. After that was working I added wavemakers, and stopped.
I am now adding float valve control with a buzzer to control a pump, and will stop.
I have learned several things in my many years with computers: never work on more than one thing at a time, if you have trouble you will not know what is broke, and then finally ( and it is very successful on this board) Ask very specific questions...
Thx and good luck
Have you tried using the Reef Angel Wizard?
Download the new Reef Angel Installer from http://reefangel.com/Download.ashx
Then go to menu Tools->Reef Angel Wizard
Give it a try and if you still have problems, come back here.
mineman@mac.com
rimai wrote:Have you tried using the Reef Angel Wizard?
I just downloaded it but there is no "Reef Angel Wizard" under tools.
rossbryant1956
had the same problem, make sure you have the 0.9.9 libraries.
I know you are using Mac. You have to also move the Arduino folder to the Documents folder.
mineman@mac.com
ok, I now have Arduino in the documents folder as well as apps. How do I verify that I have 0.9.9 libraries?
mineman@mac.com
Still no wizard...
mineman@mac.com
ok, got into the wizard. I will let you know how it goes.... Thanks.
mineman@mac.com
Ok... Wizard is great! but.... I get this error now:
The following feature was automatically added:
Watchdog Timer
Version Menu
Dimming Signal
ORP Expansion Module
Wifi
Custom Main Screen
Simple Menu
Binary sketch size: 29,742 bytes (of a 32,256 byte maximum)
dyld: Library not loaded: /usr/lib/libedit.3.dylib
Referenced from: /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude
Reason: image not found
I googled the error and this came up.
http://www.ludicroussoftware.com/blog/2 ... w-leopard/
Try it and let me know if it works.
mineman@mac.com
Once again... Roberto, you the man!
