I'm just trying to see if port 5 is currently on or off. I can write the rest of the code I just need to do a check first. I tried to do some searching but came up with nothing.
How do I see if a relay port is on or off
dmglakewood
Re: How do I see if a relay port is on or off
if ( ReefAngel.Relay.Status(Port5) )
//Do something if port 5 is on
dmglakewood
Thanks rimai just what I was looking for
alexwbush
this is extremely helpful for moonlights programmed on the same PWM as actinics!
I'm going to try this later:
if(!ReefAngel.Relay.Status(Port2))
else ReefAngel.PWM.ActinicPWMParabola();
