Troubleshooting LCD screen
ahmedess
Post by ahmedess »
Sometimes when i press the push button on the controller i get a blank screen instead of the main display screen and it stays like that until i unplug the controller from power and replug it back in
Re: Troubleshooting LCD screen
Do you have custom main screen?
ahmedess
Post by ahmedess »
Yes. It also flikers when its blank like that
Can I see the code?
ahmedess
Post by ahmedess »
// Autogenerated file by RAGen (v1.2.1.158), (03/12/2012 20:24)
// RA_031212_2024.ino
#define DisplayLEDPWM
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 4
#define PWMEXPANSION
#define CUSTOM_MAIN
#define SALINITYEXPANSION
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "pH calibration";
prog_char menu3_label[] PROGMEM = "Salinity calibration";
menu0_label, menu1_label, menu2_label, menu3_label  };
void MenuEntry1()
	ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
	ReefAngel.SetupCalibratePH();
void MenuEntry4()
        ReefAngel.SetupCalibrateSalinity();
	ReefAngel.LCD.DrawDate(6, 6);
	ReefAngel.LCD.DrawMonitor(15, 45, ReefAngel.Params, ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
	ReefAngel.LCD.DrawMonitor(15, 45, ReefAngel.Params);
        ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 75, "SL:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Salinity, COLOR_BLACK, 35, 75, 10);
	//ReefAngel.LCD.DrawGraph(5, 5);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port8Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    // Specific functions
    ReefAngel.StandardFan(Port2);
    ReefAngel.Relay.DelayedOn(Port8, 5);
    ReefAngel.Portal("ahmedess", "xxxxxxx");
    ReefAngel.DosingPumpRepeat1(4);
    ReefAngel.DosingPumpRepeat2(5);
    ReefAngel.PWM.SetActinic(PWMSlope(15,05,23,54,0,InternalMemory.LEDPWMActinic_read(),60,ReefAngel.PWM.GetActinicValue()));
    ReefAngel.PWM.SetDaylight(PWMSlope(15,0,23,59,0,InternalMemory.LEDPWMDaylight_read(),120,ReefAngel.PWM.GetDaylightValue()));
I don't see anything wrong except for the Portal() function, which should be just above ReefAngel.ShowInterface();
ahmedess
Post by ahmedess »
It doesnt happen all the time but its been happening more often lately
Was there anything added lately? Equipment change or anything?
ahmedess
Post by ahmedess »
No
ahmedess
Post by ahmedess »
It also stays lit for longer than the specified LCD timeout
I can't replicate the problem.
What happens if you remove the jumpers from the head unit?
This will disable your expansion modules, though.
Sent from my SPH-D700 using Tapatalk 2
ahmedess
Post by ahmedess »
I uploaded the code again to the controller after fixing the code as you mentioned and i ll test and see
