PH stuck at 6.99
- chachew
PH stuck at 6.99
So i reset the RA+ to factory defaults...Now my PH probe reads 6.99 and never ever changes to anything else.. I have tried with RO/DI water as well as tank water that is about 8.2 and the RA controller never changes the probe reading..
Re: PH stuck at 6.99
Did you remove the probe from the storage bottle?
You can't measure pH on RO/DI water. There is a good article from Randy that talks about pH on RO/DI and meters:
http://reefkeeping.com/issues/2005-05/rhf/index.php#8
But you should be able to read tank water.
- chachew
Yes i removed it from the storage bottle and tried to get it to read some tank water but the reading never changes. It just stays at 6.99 while in either the storage bottle or the tank water. Before i reset the controller back to default preloaded code it was reading 5.99 while in the storage bottle. Did i somehow reset the calibration by reseting the controller back to default loaded code?
ishtak
Hey Roberto,
I've got the same thing happening. I updated the libraries on my unit a week or so ago and forgot to write down the PH calibration figures. I redid the calibration and now it doesn't change from 6.99. I'll try doing another calibration tonight and let you know if that changes anything.
Justin
Justin
I don't think so, but let's check.chachew wrote:Did i somehow reset the calibration by reseting the controller back to default loaded code?
Please load this code:
ReefAngel.Init();
ReefAngel.LCD.DrawText(0,255,10,10,"Analog:");
ReefAngel.LCD.DrawText(0,255,10,20,"PHMax:");
ReefAngel.LCD.DrawText(0,255,10,30,"PHMin:");
ReefAngel.LCD.DrawText(0,255,10,40,"PH:");
ReefAngel.LCD.DrawText(0,255,70,10,analogRead(PHPin));
ReefAngel.LCD.DrawText(0,255,70,20,InternalMemory.PHMax_read());
ReefAngel.LCD.DrawText(0,255,70,30,InternalMemory.PHMin_read());
ReefAngel.LCD.DrawText(0,255,70,40,ReefAngel.Params.PH);
ReefAngel.Refresh();
- chachew
Ill test it out in a few hours when i get done diving.
- chachew
Analog: 427ish
PHMax: -1
PHMin: -1
PH: 699
PHMax: -1
PHMin: -1
PH: 699
Sounds like the calibration values went bad in the transition.
Let's load a new memory file to reset them back.
File->Sketchbook->Example Codes->InitialInternalMemory
This code should put it back the factory calibration values.
Let me know if this works.
- chachew
Ok that makes sense. I did reload through the wizard once and I would get a failure unless I loaded the code to the internal memory. So it probably overwrote the calibration...ill try this when I get home and see what happens.
- chachew
Thanks Roberto, that was the fix! I reloaded the InternalMemory and then reloaded the Preloaded Code and now the PH probe is reading correctly!
