Wavemaker coding question
tpriscu
Hi guys,
So this is the example code for random timed wave makers working opposite of eachother
ReefAngel.WavemakerRandom(Port 25,60);
// Turn Port5 on/off random cycles that lasts from 25 to 60 secs
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
// Turn Port6 on/off on opposite cycle as Port 5
Would it be possible to make the Power heads overlap each other for lets say 5 seconds in between every "wave" , just to cause a little turbulence in the water?
Re: Wavemaker coding question
We can do that, but not with that function.
Do you want it to be random and overlap too?
If so, the logic would be to calculate the random number and activate one port. Put the random number on a timer. When it is 5 seconds from expired timer, you turn the other powerhead and when the timer expires, turn the 1st powerhead. Repeat cycle again.
Does it make sense?
Does it make sense?
tpriscu
I do not need the overlap to be random, ill just stick with five seconds.
I think because im not really familiar with the functions available i cannot envision what this code would look like. Can you give me a hand with it?
Try this code:
You can change the paramenter on the random() function to increase or decrease the cycle.
void MyCustomWM()
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(10,20);
state=!state;
if (cycle<5)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
tpriscu
I'll try it tonight.
Thanks Roberto!
Thanks Roberto!
reefermadness
Really interested in this code. Was just sitting down to see if I could figure something like this out. Does it work?
reefermadness
This code is working great. My corals really appreciate the turbulence.
One small problem is that it doesn't work when my tank returns from night mode.
Anybody know how I should fix my code?
if ( (hour() >= 21) || (hour() <= 8) )
ReefAngel.Relay.Off(Port5);
if (cycle<0)
nexttoggle+=random(40,45);
state=!state;
if (cycle<15)
Try this:
nexttoggle=now();
if (cycle<0)
state=!state;
if (cycle<15)
reefermadness
It doesn't appear to like that either.
RA06242012fixwave.cpp: In function 'void loop()':
RA06242012fixwave:56: error: 'nexttoggle' was not declared in this scope
RA06242012fixwave:86: error: expected `}' at end of input
You are probably missing one last bracket at the end.
I simply copied what you have posted and I can now see there is one closing bracket missing.
reefermadness
I'll try this tomorrow. I also had to change line 5.
if (cycle<0)
state=!state;
if (cycle<15)
It won't work if you do like that.
You have to make sure to use the same structure in the 1st post I made.
The declaration of the variable was on top before the if statements.
JoshSD
I'm trying to use some of this code for the wavemakers, and am finding that after my nighttime period, which is supposed to end at 8am, that port 5 is staying stuck ON. Not continuing to follow its overnight setting which is the WavemakerRandom at 25-30 seconds, but just staying on until I reset the RA somehow, which I am usually doing by disconnecting and reconnecting the wifi adapter.
What do I have wrong? thanks in advance.
// Autogenerated file by RAGen (v1.2.1.158), (03/23/2012 13:51)
// RA_032312_1351.ino
// #define DisplayImages
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
ReefAngel.AI.SetPort(highATOPin);
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On(Port4); //Return pump
ReefAngel.Relay.On(Port8); //Skimmer
ReefAngel.Relay.On(Port2); //AI Sol Blue
// Specific functions
ReefAngel.StandardLights(Port3,20,0,6,0); //Refugium Light
ReefAngel.StandardHeater(Port1,765,775);
ReefAngel.StandardHeater(Port7,785,790);
ReefAngel.Portal("joshSD","*******");
if (hour()>=22 || hour()<=8)
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.05);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.05);
ReefAngel.WavemakerRandom(Port5,25,30);
ReefAngel.Relay.Off(Port6);
// ToDo: change wavemaker statement to
// alternate with random 10 - 20 sec cycle, then sleep 60 sec
ReefAngel.AI.SetChannel(White,PWMParabola(10,0,21,0,3,100,3));
ReefAngel.AI.SetChannel(Blue,PWMParabola(8,0,22,0,3,100,3));
ReefAngel.AI.SetChannel(RoyalBlue,PWMParabola(8,0,22,0,3,100,3));
// ReefAngel.WavemakerRandom(Port5,15,45);
// ReefAngel.WavemakerRandom1(Port6,15,45);
// change to have wavemakers alternate and overlap 5 seconds
if (cycle<0)
nexttoggle+=random(45,60);
state=!state;
if (cycle<5)
// PWMParabola(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
// startHour - Hour of the start the slope
// startMinute - Minute of the start the slope
// endHour - Hour of the end of the slope
// endMinute - Minute of the end slope
// startPWM - Beginning PWM value
// endPWM - Ending PWM value
// oldValue - Should be the startPWM value or the existing/current PWM value (ReefAngel.PWM.GetActinicValue() or GetDaylightValue())
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
byte WhiteValue=0;
byte BlueValue=0;
if (cycle<0)
state=!state;
if (cycle<5)
carlii
What do the numbers in :
mean?
mean?
It means that the next toggle will be a random number between 40 and 45 seconds.
JoshSD
is there a simple way to add a "sleep" timer in between the toggles? So that I can do something like
Wavemaker 1 comes on for random time between X and Y seconds
When that time is complete, there is a delay of Z seconds
Wavemaker 2 comes on for random time between A and B seconds
when complete, delay of Z seconds
etc.
etc.
That's what this code was, but instead of having them off for Z seconds, they were on for Z seconds.
You can change the code to off instead of on.
