Can you help to code..
Ask in here.
kimacom
Post by kimacom »
Hi,
I just got the RA+, wifi and tried many things :D
I know this is great controller, btw i need to know how to code first.. :( not easy..
my qestion is
If port #5 "always on" and it off by accidentally or on purpose,
is it possible to turn on automatically after cetain time out? like turn on after 5min or 1hr
thanks ahead
Tim
Re: Can you help to code..
Try this:
unsigned long LastPort5On=now();
  ReefAngel.Init();
  ReefAngel.Relay.On(Port5);
  if (ReefAngel.Relay.Status(Port5)) LastPort5On=now();
  if (now()-LastPort5On > 10)
    ReefAngel.Relay.RelayMaskOff|=Port5Bit;
It's set for 10 seconds, but you can change to whatever number of seconds you would like.
kimacom
Post by kimacom »
Great, so is this ok port#5,6 turn on after 5min, 4hr?
unsigned long LastPort6On=now();
ReefAngel.FeedingModePorts = Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.StandardLights( Port2,9,0,11,0 );
ReefAngel.StandardHeater( Port3,775,785 );
ReefAngel.StandardFan( Port4,785,805 );
ReefAngel.Wavemaker( Port5,0 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port8 ) );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,19,0,12,40,12) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,23,0,12,40,12) );
if (now()-LastPort5On > 300)
if (ReefAngel.Relay.Status(Port6)) LastPort6On=now();
if (now()-LastPort6On > 14400)
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.RelayMaskOff|=Port6Bit;
ReefAngel.Portal( "kimacom" );
if wrong, please correct me,
and one more question, there is port #7 (opposite #8 ) could be delayed on start after #8 off?
thanks again
Tim
You were just missing on last closing bracket on your last if statement.
Other than that, it looks good to me :)
Good job!!
You could use same concept for Port 7.
Declare a new variable up top
Then keep checking for status of port 8 and do something if the delay expires.
Try this:
unsigned long LastPort8On=now();
 ReefAngel.Relay.Off(Port7);
if (ReefAngel.Relay.Status(Port8)) LastPort8On=now();
 if (now()-LastPort8On > 3)
 ReefAngel.Relay.On(Port7);
kimacom
Post by kimacom »
Great.
so, port#7 will be turn on 3sec after port#8 off, right?
and can i give the time out port#7 for during like 10min?
or it will turn off automatically after port #8 turn on
because i use port #7 as water change pump(sump water out) so,
should i turn on port #8 first(means water change mode off) or just give exact time out for port#7(which means not opposite port #8)
i am confusing...
Thank you Sir!
Have a nice day.
just to chime in, this type of changes could prevent water change and feeding change modes. this just means that if the ports get turned off by those modes that they will get turned back on by your code overrides.
kimacom
Post by kimacom »
Yes, you are right.
So, I just remove the main pump port to manual switch, so i can turn it on and off with water change pump as well.
thanks
