2 questions.
How do I change the local time on my RA
My temp probe is not reading the water temp do i need to turn it on?
newbie questions
newbie questions
-Dave
Re: newbie questions
If you have wifi:
This last one takes quite a bit of space. If you have a standard RA, it may be too big. If you have RA+, you don't need to worry about space.
- Android app
- Client Suite
- Reef Angel Status
- Portal
- Preloaded code
- Add this to your setup() section of your code:
ReefAngel.AddDateTimeMenu();
No, you can read the temp probe with the standard RA. He was just telling you how you can change the date & time of the controller.Thavngr98 wrote:seriously? I cant read the temp probe with the standard RA?
If the probe is not reading properly (or at all), make sure it is plugged in fully and restart the controller (pull the power and then plug it back in).
What is the temp probe reading? Is the temp probe placed in the water (I know, silly question, but still worth asking)?
never silly questions. LOL yes its in the water. I have it plugged into the temp connection clostest to the ph probe
-Dave
newbie questions
Still getting error on temp1
Also I am having issues calibration the ph probe. When in calibration mode for 7 I get 599 nothing higher. I'm using pinpoint #7 fluid. Any secrets?
-Dave
newbie questions
It says on the ph #7 that at 68 degrees the ph will be 7.036 I get a reading of 558 in calibrate mode#7
-Dave
