Problem with lights not turning off
So I have had issues with my t5s not turning off. The controller says the port turns off but lights stay on. I have tried moving ports and such but it's happened with two different lights so far. Was working and turning off for a week and now they stayed on again. It's hard for me to get code from the computer I am using too but if needed I can find a way.
Re: Problem with lights not turning off
we need you to post the code. Email it to me and I'll post it so we can all look at it. Sent you a PM
I will have to find a way to get it off the computer tomorrow mourning.
I have two 250s on the first box and one 400 on the second.
I think this is all the code.
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
InternalMemory.OverheatTemp_write( 821 );
ReefAngel.StandardLights( Port1,9,30,18,30 );
ReefAngel.StandardLights( Port2,12,0,17,0 );
ReefAngel.StandardLights( Port3,12,0,17,0 );
ReefAngel.StandardLights( Port4,9,30,18,30 );
ReefAngel.Wavemaker( Port5,240 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardLights( Port7,10,0,18,0 );
ReefAngel.StandardLights( Port8,9,30,18,30 );
ReefAngel.StandardLights( Box1_Port1,12,0,17,0 );
ReefAngel.StandardLights( Box1_Port2,11,45,17,30 );
ReefAngel.StandardLights( Box1_Port3,11,45,17,30 );
ReefAngel.StandardLights( Box1_Port4,11,45,17,30 );
ReefAngel.Wavemaker( Box1_Port5,240 );
ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardLights( Box1_Port7,17,0,2,0 );
ReefAngel.StandardLights( Box1_Port8,17,0,2,0 );
ReefAngel.Portal( "Piper27" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
// Date and Time
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
So far one and four on box one and seven and eight on box two...
2 ballasts in the same port is always not a good idea.
Are all 4 ports stuck on now?
Can you use the ControllerTester code to go through each port?
File->Sketchbook->Example Codes->ControllerTester
No each ballast is in a separate outlet. The ports randomly work when they want. Port 7 on the second box has worked since I assigned it so far, port eight on box 2 has never turned on but said it was on (I think that's what happened). Port One on box one has never actually turned the lights but turned them on the first mourning. Port four box one worked for a few days this week and now tonight didnt shut off. I will try and use the control tester in the mourning. Why am I having so much trouble with this issue? How do I fix it?
What am I looking for, or what does this test do? I am getting kinda worried that something is wrong, I have so much equipment that I moved so I could hook this thing up I can't imagine moving everything back and using my old controller.
Also if I plug it in the outlet it makes a pop noise and I see sparks. Doesn't seem good at ALL.
Roberto I went to the controller tester, I am not sure what I am supposed to do once I get there.
Test each port.
If you press the joysick, it will turn every single one of your ports.
You can only do that on the main relay box.
So, test one box and hook up your other box as main box and do the test again for your other one.
Do all ports turn on and off accordingly?
Okay so with this thing port four worked when I manually did it. Port one still won't turn off.
That's a lot of plugs to mess with to figure that one out. I am confused on how this is going to help, I mean Port four worked just a min ago when I tested it, but two nights ago it wouldn't turn off. It worked for a week before that. So why am I testing ports if I know that they can still not turn off at random times? I can unscrew the second relay if I have to test it for some reason.
We are just trying to find out here what is causing the issue.
We know it is hardware related by what you found out with the main box.
If the expansion relay box is not accessible, we change the code to send signals to the expansion box too.
Let me get to a computer to change it.
I see I will unplug everything and unscrew everything to hook it up I a little bit. I will get back to you, appreciate the help!
Use this code for the expansion relay box:
int port=0;
ReefAngel.Init();
This code will display:
Temperature probes
pH probe
Daylight PWM % (if the feature is enabled)
Actinic PWM % (if the feature is enabled)
Relay box
Time/Date
ATO port status
It will blink the red status LED and increment the PWM % every second.
Moving or pressing the joystick will activate another port in the relay box.
if (ReefAngel.Joystick.IsUp() || ReefAngel.Joystick.IsRight()) port++;
if (ReefAngel.Joystick.IsButtonPressed()) port++;
if (ReefAngel.Joystick.IsDown() || ReefAngel.Joystick.IsLeft()) port--;
if (port>7) port=0;
if (port<0) port=7;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,10,"Port On");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,45,10,port+1);
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,20,"Low ATO");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,65,20,"Closed");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,65,20,"Open ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,30,"High ATO");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,70,30,"Closed");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,70,30,"Open ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,40,"Status LED ");
if (now()%2==0)
ReefAngel.LED.On();
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,80,40,"On ");
ReefAngel.LED.Off();
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,80,40,"Off");
ReefAngel.Relay.RelayData=1<<port;
//Box1_Port
ReefAngel.Relay.RelayDataE[0]=1<<port;
ReefAngel.PWM.SetActinic(now()%100);
ReefAngel.PWM.SetDaylight(now()%100);
ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params);
ReefAngel.LCD.DrawOutletBox(12, 103, ReefAngel.Relay.RelayData);
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.Relay.Write();
ReefAngel.Refresh();
Thanks, so the second box everything turned on and off correctly.
I rechecked the first box and it's still only port one that is not turning off.
Ok, so we know 1 port is bad.
You got PM.
Since you tested the others and they all seem to be working, ca we move some stuff around and see what happens?
I've changed you code a little to switch some stuff around and staggered them so they turn on/off at different times, instead of all at once.
Can you let me know what you observe?
You got PM.
ReefAngel.StandardLights( Port1,12,0,17,0 );
ReefAngel.StandardLights( Port2,9,31,18,31 );
ReefAngel.StandardLights( Port3,9,30,18,30 );
ReefAngel.StandardLights( Port4,12,1,17,1 );
ReefAngel.StandardLights( Port8,9,32,18,32 );
ReefAngel.StandardLights( Box1_Port1,12,2,17,2 );
ReefAngel.StandardLights( Box1_Port3,17,0,2,0 );
ReefAngel.StandardLights( Box1_Port4,17,3,2,3 );
ReefAngel.StandardLights( Box1_Port7,11,44,17,29 );
ReefAngel.StandardLights( Box1_Port8,11,43,17,28 );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
BTW, what did you have plugged in into the port1 of main box, which is the one that is bad?
I have a Icecap with 4 39w t5s.
