The Nutrient Tranpsort mode has two phases with a wave motion phase and surge phase. It's doing the wave motion phase okay but it's not going into the surge phase. Can you take a look at my code and see what I might be missing?
I did try using the wizard for this but I couldn't get the feeding mode didn't work correctly. The vortech pumps would only stay in feeding mode a few seconds before reverting back to nutrient transport. I copied most of this from someone elses code and just removed their automatic feeding cycles. I also noticed the wizard called the mode as NutrientTransport and the user I copied code from called it as Smart_NTM, not sure if there is a difference?
// Autogenerated file by RAGen (v1.2.2.171), (07/19/2012 20:00)
// RA_071912_2000.ino
#define DisplayImages
#define DateTimeSetup
#define DosingPumpSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define RelayExp
#define InstalledRelayExpansionModules 1
#define WDT
#define PWMEXPANSION
#define IOEXPANSION
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
#include <avr/wdt.h>
// Globals Needed for Params on Custom Main
byte x,y;
int v;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, "Sean's 58G Money Pit");
// Display T2 Header Text
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,255,8,14,"Tank");
// Display the T2 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE, 255, 4, 24, text, Num8x16);
// Display the T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Room");
// Display the T1 Temp Value
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display Vortech MP10wES Mode Header Text
ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
// Display PMW Expansion Channel Headers and % Values
ReefAngel.LCD.Clear(DefaultFGColor,5,65,127,65);
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,31,68,"LED Dimming");
x=15;
y=78;
for (int a=0;a<4;a++)
if (a>1) x=75;
if (a==2) y=78;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch :");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+12,y,a);
ConvertNumToString(text, ReefAngel.PWM.GetChannelValue(a), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,text);
y+=10;
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
// Display Expansion Relay Box 1
ReefAngel.LCD.DrawOutletBox(13,109, TempRelay);
//Draw Date & Time
ReefAngel.LCD.DrawDate(6, 123);
void DrawCustomGraph() // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
//Ports that are always on
ReefAngel.Relay.On(Box0_Port4);
ReefAngel.Relay.On(Box0_Port5);
ReefAngel.Relay.On(Box1_Port4);
ReefAngel.Relay.On(Box1_Port5);
ReefAngel.FeedingModePorts = Port5Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
// define T2 probe as temp probe
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit ;
//--------------------------------------------------------- RF Module Setup -------------------------------------------------------
ReefAngel.RF.SetMode(Slave_Start,0,0);
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'RF'
Please make sure that you enabled RF Expansion on your features file.
Open RAGen and make sure you have RF Expansion checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define RFEXPANSION
InternalMemory.RFMode_write(5);
InternalMemory.RFSpeed_write(170);
InternalMemory.RFDuration_write(11);
//------------------------------------------------------ End RF Module Setup ------------------------------------------------------
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
ReefAngel.StandardLights(Box0_Port1,11,0,22,0);
ReefAngel.StandardLights(Box0_Port2,23,0,10,0);
ReefAngel.StandardLights(Box0_Port3,10,0,23,0);
ReefAngel.StandardLights(Box1_Port8,10,0,23,30);
ReefAngel.StandardFan(Box0_Port6, 773,777);
ReefAngel.StandardFan(Box0_Port7, 775,790);
ReefAngel.StandardHeater(Box0_Port8,768,770);
ReefAngel.DosingPumpRepeat(Box1_Port3,0,360,600);
ReefAngel.PHControl(Box1_Port1,824,828 );
ReefAngel.PWM.SetChannel(0,PWMSlope(11,0,22,0,12,40,60,10));
ReefAngel.PWM.SetChannel(1,PWMSlope(10,0,23,0,12,100,60,10));
ReefAngel.PWM.SetChannel(2,PWMSlope(10,0,23,0,12,100,60,10));
ReefAngel.PWM.SetChannel(3,PWMSlope(10,0,23,0,12,100,60,10));
ReefAngel.Portal("", "");
//------------------------------------------------- End PWM Expansion Code for Slope ----------------------------------------------
//------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
if (hour() >=10 && hour() <= 23)
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,170,11);
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
//---------------------------------------------------------- End RF Daytime Control -----------------------------------------------
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<10) // Defining "Nightmode" hours for VorTech = between 11 PM and 10 AM
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
