I was wondering if there is already code setup in the controller out of the box for dimming LED's? Currently I am building a new fixture with dimming. If I use the Actinic and daylight plugs on the relay box that are already on timers to shut them off and turn them on and then connect the dimming ports to my new power supplies is there already an exsisting dimming curve?
Also is the code easy to change as far as the dimming? I want to adjust the max voltage so I can aclimate new corals...
Thanks in advance,
Jeremy
Dimming curves... LED
Re: Dimming curves... LED
Out of the box you have a parabola wave form for both channels.
You can change it to a slope shape, but would require you to upload another code.
That is exactly what I want, is there an easy way to change the max intensity, or would I have to change the code?rimai wrote:Out of the box you have a parabola wave form for both channels.
Press the joystick to access menu and go to LED setup.
You will be able to set the max intensity for both channels individually.
You can find more info on the user manual.
Thank you sir!!!!rimai wrote:Press the joystick to access menu and go to LED setup.
