Timeout error
Ask in here.
stephy
Timeout error
Post by stephy »
Today I updated libraries and try to upload a new code to my RA. Before I never had problems uploading.
arduino log:
Watchdog Timer
Version Menu
Dimming Signal
RF Expansion Module
Wifi Attachment
Date/Time Setup Menu
Simple Menu
Dimensione del file binario dello sketch: 35.534 bytes (su un massimo di 258.048 bytes)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\TINOZ2~1.5\AppData\Local\Temp\build8625544596654132806.tmp\ott23.cpp.hex:i
avrdude: Version 5.11.1, compiled on Apr  1 2012 at 09:58:16
         System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Recv:
avrdude done.  Thank you.
my code:
  ReefAngel.AddDateTimeMenu();
  ReefAngel.AddWifi ();
  InternalMemory.OverheatTemp_write( 309 );
  ReefAngel.Relay.On( Port4 );
  ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Tinozzina"); // Display Reef Angel banner
  ReefAngel.DayLights( Port2 );
  ReefAngel.MoonLights( Port3 );
  ReefAngel.StandardHeater( Port5 );
  ReefAngel.StandardFan( Port6 );
  ReefAngel.Relay.DelayedOn( Port7 );
  if ( ReefAngel.RF.Mode != Feeding_Start)
    if (hour()==9)
      if (minute()>0)
        ReefAngel.RF.SetMode( Lagoon,65,10 );
        ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
    else if (hour()==10 && minute()<5)
      ReefAngel.RF.SetMode( Constant,90,10 );
    else if (hour()==13 && minute()<30)
      ReefAngel.RF.SetMode( Smart_NTM,90,3 );
    else if (hour()==19 && minute()<5)
    else if (hour()==20 && minute()<30)
    else if (hour()==21)
    else if (hour()>=22 || hour()<10)
      ReefAngel.RF.SetMode( Night,80,10 );
      ReefAngel.RF.SetMode( ReefCrest,75,10 );
  ReefAngel.Portal( "stephy" );
Suggestions?
Stephy
Re: Timeout error
You seem to be using the wrong version of avrdude.
The avrdude version you have is not the correct one.
This is the original distribution from the Arduino team and I actually recompiled to create a RA specific avrdude.
Let me check if the RA installer has the wrong version.
Re: Timeout error
Yeah :(
I packaged the wrong avrdude.
Let me repackage it. Sorry.
Re: Timeout error
Ok, I repackaged it and updated the download section of website.
Please download the newest installer 1.0.2a
stephy
Re: Timeout error
Post by stephy »
Working, thanks :-)
Any news about new version of client suite...?
Stephy
Re: Timeout error
Dave is working on that and he had some problems with Windows8 compatibility.
