need help with dosing pumps
Meshmez
Post by Meshmez »
Ok, so im having trouble with setting up dosing pumps...
Here is what i want to do..
I want to be able to enter my TOTAL daily dosing time in the "runtime" memory spot.
I then want to have my calcium dose that amount evenly, hourly, over the 24hour day, with a 30 minute offset (so 12:30, 1:30, 2:30 etc) (runtime/24hr=hourly dose time.) so for instance if i want 60 minutes of dosing daily, i want calcium to dose 60min/24doses= 2.5min every hour.
What I want for my alkalinity is a little tougher. I want it to dose more at night than during the day. i want it to dose 1/3 of the total from 1PM-1AM, and 2/3 from 1AM to 1PM. I want to do this to try to help level my PH over night. I want it to dose every 30 min.
so from 1PM-1AM i want (60min/3)/24doses=0.83 minutes every 30 min.
and from 1AM-1PM i want ((60min/3)/24doses)*2= 1.66minutes every 30 min.
can i just do what i have below, with the runtime memory set to 3600sec? also, on the android app, which memory location corresponds to that runtime memory location?
// Dosing
//Calcium
ReefAngel.DosingPumpRepeat(Port1,30,60, int RunTime/24);
// Alkalinity
if ( hour() >= 1 || hour () <= 13 )
ReefAngel.DosingPumpRepeat(Port8,0,30, ((int RunTime/3)/24)*2);
ReefAngel.DosingPumpRepeat(Port8,0,30,((int RunTime/3)/24));
Sorry if im totally missing something here...
Re: need help with dosing pumps
I'm afraid the dosing timer memory location is byte size and not int :(
Even though the function takes int size.
So, you would have to use a custom memory location. Is it ok?
Let's say you pick memory location 150 and store an int size value.
Then, you could use this:
  // Dosing
  int RunTime = InternalMemory.read_int(15);
  //Calcium
  ReefAngel.DosingPumpRepeat(Port1,30,60, RunTime/24);
  // Alkalinity
  if ( hour() >= 1 && hour () <= 13 )
    ReefAngel.DosingPumpRepeat(Port8,0,30, ((RunTime/3)/24)*2);
    ReefAngel.DosingPumpRepeat(Port8,0,30,((RunTime/3)/24));
Meshmez
Post by Meshmez »
ya using a memory location is fine, just wasnt sure how to do it, and i wasnt sure if i could do that math in the code or not. :)
I guess in that case i might as well take it one step farther and make it so i can just enter my dose amount in mL and add to the equation in the code to convert that to seconds. so i could enter 100 for 100ml, and then in the code just add ((runtime/1.1)/60) since the pump is 1.1mL/min
to confirm, for location 150 the code is:
or was the (15) supposed to be (150)
so is that code basically just naming internal memory location 150 = "runtime" so when i enter runtime into the code it looks there for the int value?
It was a typo :( Good catch :)
You need this:
int RunTime = InternalMemory.read_int(150);
Meshmez
Post by Meshmez »
Great, Ill give it a shot tonight.
Thanks for the quick response as always Roberto!
