port 2 relay box
port 2 relay box
Port 2 of my relay box does not seem to be working. I have it set to always on and have no power at the socket. When I plug a lamp into it and cycle it from off to on the lamp flashes but then goes off. Anything I can do to fix it.
Re: port 2 relay box
Can you try the ControllerTester code?
Go through each port and see if they work properly.
File->Sketchbook->Example Codes->ControllerTester
I used the test code and I can hear the relay change positions but when I plug something in and cycle relay the item just comes on for a flash. It seems like the relay is not latching it is just closing and reopening
Roberto, I'm having a similar issue. I just received my RA unit in the mail today, set everything up (incl. wifi adapter), everything seemed to be working fine until I noticed that my skimmer pump wasnt running. So I loaded up the controller tester sketchbook and port 8 (skimmer) wasnt working (could hear the relay switch on/off). Also while testing each port I noticed relay 5 (koralia nano) wasnt working either, the port just made a humming/screeching sound. All other ports seem to be working as they should. Luckily I'm just testing this on my currrent setup as I will be using the RA on my current project that is nearly set up and ready to go. Here is my code as I have it right now:
Could the port 5 (Koralia) problem be because it's after "lights out"? But I dont understand why port 8 (skimmer) isnt working. Thanks in advance.
ReefAngel.AddStandardMenu(); //Standard Menu
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.MoonLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.ActinicLights( Port5 );
ReefAngel.MoonLights( Port7 );
ReefAngel.Portal( "jabregousmc" );
Humming is not a normal sign. Looks like you got a defective box.
By using the ControllerTester code, you should be able to turn on and off all ports.
PM for RMA.
PM for RMA.
Well unfortunately since I just registered yesterday, I cannot send PM's yet. Email or use the "contact us" form on the site?rimai wrote:Humming is not a normal sign. Looks like you got a defective box.
PM for RMA.
