Why didn't PWM dimming go to zero?
dadriance
Post by dadriance »
I finally finished my new lighting yesterday and got it all set up. Channel 0 is moonlighting and channels 1,2 and 3 are royal blue, violet/blue/cyan and white. Everything ran well all day, the levels went up and down as they should all day. The glitch came when I checked on it after the lights should have been out, channel 3 was still at 1% instead of 0. My moonlight is already on the bright side, adding 10 white LEDs, even at just 1%, made it more dusk than night.
I double checked, the 3 channels are all set to "start" at 0 and peak at 35 to 55 (varies by channel). Why didn't this channel shut down and how do I fix it?
While I'm asking questions about this expansion, is therer a way to use the moonlight program but reduce the brightness? I won't know for certain untill I get the white channel sorted but I suspect that 4 3w LEDs at 150mA will be a little bright, is there a command for "moonlight=PWM level/2."
Re: Why didn't PWM dimming go to zero?
Can you post your code?
dadriance
Post by dadriance »
It's been a while, I hope this works correctly...
Created with the wizard.
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port8Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.StandardHeater( Port8 );
    ReefAngel.PWM.SetChannel( 0, MoonPhase() );
    ReefAngel.PWM.Channel1PWMParabola();
    ReefAngel.PWM.Channel2PWMParabola();
    ReefAngel.PWM.Channel3PWMParabola();
    ReefAngel.Portal( "dadriance" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // Parameters
    // Main Relay Box
    // Date and Time
I wonder if the parabola is not going to zero because of the floating point math calculations.
Let's try this.... Change this:
With this:
  ReefAngel.PWM.SetChannel( 3, PWMParabola(
  InternalMemory.StdLightsOnHour_read(),
  InternalMemory.StdLightsOnMinute_read(),
  InternalMemory.StdLightsOffHour_read(),
  InternalMemory.StdLightsOffMinute_read(),
  InternalMemory.PWMSlopeStart3_read(),
  InternalMemory.PWMSlopeEnd3_read(),
  0));
dadriance
Post by dadriance »
Thanks Roberto! I'll give that a try after lunch and see how it goes tonight.
I did find that I have another anomoly that is probably related. As I was reading the code you posted, my white lights suddenly dimmed, it had seemed brighter than expected until then but I thought it was because I had lowered the fixture. after a little troubleshooting I noticed that the display showed my white channel at "102." This channel is set to start at 0 and go up to 55, 102 couldnt be right and it's way too dim to be at >100%. I increased the max to 60 and the lights instantly came on again, the portal dropped from 106 (by then) to 21 so I think it's working correctly again but the control display has continued to climb, it seems to be displaying the correct reading but with the extra "tenths" digit showing. Currently it's up to 306, i'm sure the portal will show 30 when I go there after posting.
Any thoughts?
Should I also mention that I've been getting "Error 23: XML SAX Parser" almost all the time from the Android app for the last day or so. Related?
Edit; Yup, channel 3 is reading 314 on the display and 31 on the portal. Channels 0,1 and 2 are reading normally.
Edit 2; I've modified the code and the controler is now reading "34" for channel 3.
dadriance
Post by dadriance »
My whites shut off correctly last night. Thanks again for the help.
dadriance
Post by dadriance »
Here we go again...
My white channel is still fine, but for t last few nights my other 2 channels have stayed at 1%. Obviously I could add the same code for those 2 channels (if I have enough memory) but I was wondering if there were something I could put in place to take care of all channels at once, instead of adding code for each channel.
I don't think the code increases.
The short version Channel3PWMParabola is just the same as the bigger version except the latter is forcing the channels to go to zero instead of the parabola calculation.
I think the last 1% is rounding off from the mcu we use can't really do floating point math calculations and it just rounds off to the wrong value.
If you want to force to zero, you would need to hard code that last zero value on the bigger version.
